Peter (archive)
Usenet Archive
- Joined
- Mar 23, 2000
- Messages
- 1,273
- Reaction score
- 0
Help and expertise desperately needed....
My kitchen lighting circuit is not working.
Circuit breaker checks out and I have a ceiling/fan and receptacle in another room on the same circuit that works. When checking the romex cable coming off the receptacle to the first kitchen light..the black wire has continuity, but the white (neutral) does not. I disconnected the wire pair at both ends, (fixture and receptacle) and connected wires together.
Tested with no continuity.
Final test.... I ran another neutral from the panel to the first fixture and all the lights are working.
So it looks as if the neutral is defective. But it's about 15 feet away from the fixture, traveling inside a wall and through the ceiling.
How does one replace a cable run in the wall. Does this mean tearing down the sheetrock both on the ceiling and in the wall???
Are there tools or meters available that test out a break in a wire ???
I'm thinking that hiring an electrician might be a good idea ??? Can they do this job faster than a DIY'er and approximately what would they charge ??
Thanking you in advance for your help and recommendations !!!
Peter
Peter
