Removing non-stick coating to salvage a pan?
Doc
I've got this wok from WalMart that's coated with Xylan, which I
gather is a first cousin of Teflon. Big mistake. It's non-stick
properties aren't very good.
I don't like the idea of simply throwing it out and dumping more money
into a non-coated wok. I'm sure I could strip the coating off with one
of these fibrous abrasive wheels that you bolt onto a hand drill -
wearing a dust mask of course - but is the surface that's exposed
going to be suitable for cooking? Wondering if there's some pre-
treating that's done to the metal that might render it toxic if used
as a cooking surface.
Further, should it be possible to thoroughly remove all the coating
abrasively like that? Obviously I don't want to leave behind small
particles since I assume it's toxic.
JoeSpareBedroom
Drill drainage holes in the bottom and make it into a planter for small
cactus. Buy a new one. Seriously. Make sure the next wok is plain metal.
Non-stick pans shouldn't be used at the high heat levels typical of wok
cooking. I don't care what the manufacturers say.
Robert Allison
It wasn't from walmart, but I did exactly this to a large wok
that I just didn't want to throw away. I used a wire wheel on a
side grinder to remove the teflon, then sanded it lightly with
emory cloth to remove the rest and smooth everything out. I have
been using it for about 5 years like that.
The problem is that the metal is very prone to rusting, so I have
to oil it after every cleaning, and temper it like a cast iron
pan. Since I mostly use it on a fish fryer grill (although I
will use it on the stove), it has held up pretty well. It ain't
pretty by any means, but useful.
cybercat
It's going to be aluminum.
Z
zxcvbob
Sand blasting would remove the coating pretty easily, and the rough
surface should smooth out and "season" fairly quickly with use;
especially if you use steel utensils.
Bob
O
Oren
I found out how to remove "Teflon". Simmer tomato sauce for a couple
of days. When you toss the sauce out the Teflon goes with it :))
The acid destroyed the Teflon.
Charles van Blommestein
I have a few similarly well worn pans in my kichen cubbard.
With the "more recent" (w.i. the past 20-30 years) years of cookware,
the metal base is very likely ALUMINUM, which when heated is very
toxic.
What I did and recommend is to simply continue cooking with the Xylan
surface by using THICK COATS of the non-stick spray-on cooking oils or
simply let the 4-leg use this worn pan as a drinking bowl.
DerbyDad03
toxic.
simply let the 4-leg use this worn pan as a drinking bowl.- Hide quoted text -
- Show quoted text -
re: let the 4-leg use this worn pan as a drinking bowl
SWMBO would kill me - not because I let the dog drink out of a pan,
but because I tried to give her dog cancer.
She's convinced that any and all non-stick surface coatings are toxic.
John Weiss
Why bother removing it? Just use it with a little oil!
O
Oren
Listen to her :)
(ever buy a pet bowl with Teflon?)
JoeSpareBedroom
Oren said:
Listen to her :)
Even better: In some Chinese restaurants, you can see the kitchen. Ever
seen a non-stick wok in a place like that?
Of course not.
DerbyDad03
Of course not.
re: Even better: In some Chinese restaurants, you can see the
kitchen. Ever seen a non-stick wok in a place like that?
Even better: Ever seen a 4 legged creature in a place like that? Of
course not - not alive anyway..
PaPaPeng
Of course not.
A polymer coating would never survive the frequent stabbling with a
wok spatula that goes with Chinese cooking.
I am amazed so many white folks use the wok. I'd use one too except I
have an electric range. It uses up too much power to get the wok to
temperature and that heat is concentrated on the bottom only.
Only a gas range or open fire does a wok justice. Use an uncoated
heavy iron or steel wok. It holds and distributes the heat to provide
a better heat gradient from the center to the rim, sort of like why
people prefer to use a cast iron skillet to bring out the best
flavoring and texture. To clean empty the wok and add a cup of water
to heat over the range. Swirl the boiling water to dissolve the
residual food. Chinese restaurants use a stiff bamboo whisk to
unstick food morsels. Its unlikely you can use a whisk in a home as
the whisk will flick dirty water outside the sink. A few quick
swipes with a souring pad should suffice. Repeat. Rinse each time.
Wipe with a paper towel and "burn" off the remaining rinse water
adhering to the wok over the range. In an iron wok the residual heat
is often enough to vaporize that dampness.
Phisherman
Sell it, give it away, etc. Get yourself a nice heavy wok with sturdy
handles. You'll find better quality at a kitchen or specialty store,
and it will be the last wok you buy. Always prep a wok with a
high-temperature cooking oil before adding the food. Peanut oil is a
good choice. Woks work better with natural gas stoves.
O
Oren
Spoken like a true abused kitchen slave. Wife trouble?
Not when I cook in the yard, declare my turf and so. I'm going to
China town in Las Vegas and get me a wok. Might have the bride drive
me.
Nice try!
