refrigerator condenser fan not working
davidl
Hi, I have a SubZero refrigerator and the condenser fan stopped
working. I took out the fan and checked it is ok. But the voltage
supply to the fan is only 37 volts instead of 110V.
can someone tell me what can cause this. TIA.
pjm
Post in alt.home.repair, not here.
Click here every day to feed an animal that needs you today !!!
http://www.theanimalrescuesite.com/
pjm
O
Oscar_Lives
Sounds like a clog in the wiring.
O
Oscar_Lives
N
Noon-Air
Get an electrician to check your shorts :)
N
Noon-Air
Jake
I check shorts with a Megger... I don't think he'd like that too much.
Jake
Jake
Jake
Stormin Mormon
I've worked on a couple Sub Zeros. Complicated gadgets. Does the compressor
run at all?
Did you try the fan with a suicide cord, and see if the fan is OK?
Christopher A. Young
Learn more about Jesus
www.lds.org
www.mormons.com
Stormin Mormon
run at all?
www.lds.org
www.mormons.com
JOHN D
Maybe you should post the model number. My Sub 550 came with a wireing
diagram. If you don't have one SubZero will probably send you one. Does the
compressor run?
Try www.subzero.com
JOHN D
compressor run?
Try www.subzero.com
