refinishing wood floors
mo
OK, I have a house built in the 1930`s with Northern
Pine as my bedroom floors. I just finished sanding off all the old
finish. My question is do I need to seal the floor before I polyurathane
it or is it not necessary to seal before the finish?
Also what is a good sealer and polyurathane? Or should a varnish
or shellac be used instead of poly? Thanks
E
Edwin Pawlowski
No sealer is needed. If using an oil based poly, thin the first coat with
mineral spirits about 20%.
Polyurethane is a varnish. Many floor finishers use the water base as it
does not have the odors of the oil based. Water is more clear, oil gives
warmer color.
I like shellac, but it is rarely used on floors these days. Poly is usually
easier to care for and is very durable.
jeffreydesign
Polyurethane can be both your sealer and your final finish. If you're
staining your floors first, most stains have a sealer in them. Do not
mix poly and shellac or varnish finishes. Poly will be one of the the
toughest finishes you can apply if done right (it's what they use in
roller rinks - imagine the abuse there!) If you want a harder poly
finish consider catalyzed polyurethane (also known as a swedish finish)
- however beware that this kind of finish can be difficult to work
with. First the fumes can all but kill you, the working time is
relatively short and whatever it gets on, it stays on (like tools.) For
most folks, catalyzed poly is best left to professionals, but I was
able to apply it myself (by carefully following instructions) with
great results.
Jeff
