Raymond weil wrist watch battery change
Martin Tinter
'have been trying to change the battery of a raymond weil wrist watch (older
othello model with moon phases and year-date-handles). I can't find my way
to the battery as I could only remove the glass. does anyone know if you
have to remove all the handles to get inside.
thanks for any help
martin tinter
E
Edwin Pawlowski
thanks for any help
martin tinter
Can't go through the back like every other watch? Before you screw it up,
take it to a jeweler and pay the $3 to have them put a battery in.
Ed
ChrisM
.... and if you take a hammer and chisel to a 'Raymond Weil' you deserve
everything that happens to you/it...
thanks for any help
martin tinter
Someone told me that , the REAR cover is "CENTER" , use Blade to POP it UP for replace Battery ?hope that will help
Finally , i found the answer , MUST use "WORKBENCH-cover-remove tool" , LOCK in the crew TIP on the " OUTER case" you can the GAP .... the TURN 90 degree to OPEN it . this is for Raymond weil OTHELLO model " 128"
