Radiator , every one is fine except one !!!
Discussion in 'UK Home Improvement' started by Dave T, Jun 26, 2007.
  1. Dave T
    Dave T Guest
    Basically , combi boiler , 8 radiators in total in the house , all other
    radiators are fine , except one , it works fine , but over say a month it
    tends to end up full of air ? so i use the key to open the valve and let the
    air out , usually quite a lot and then its fine for say 4 weeks ?!!? the
    rest are perfect , this radiator in question is on the same floor as the
    combi boiler and is perhaps only 3 meters away , but why only 1 radiator out
    of all of them have this problem ?
