Radiator Bleed Valve
RedOnRed
I bled a radiator last week and the bit that unscrews slightly sheared off
and started a slow dripping leak from the rad. I've isolated the rad
but it's now unusable until I've got a replacement part.
We're covered by E-on central heating cover who I rang last Saturday and the
soonest they can come out is Thursday (time wasters) I know
it's then going to take them weeks of messing about trying to order it, so
I'm trying to get it myself as it would be cheap and easy to fit anyway.
Right, getting a replacement part (a radiator bleed valve) is proving to be
the ultimate unforeseen challenge. Yesterday, in my lunch break I
went to...
Buildbase> B&Q> BSS> Plumbcenter> & Graham's and unbelievably not one of
them has the part.
It's quite hard to describe the part but I think the rad is by Centerrad and
it was fitted about 5 years ago. It's a traditional single rounded top style
and the bleed valve is on the right hand side, sort of offset at angle
(looking down on it). The full part (a sort of bolt that unscrews) is
about 10mm long and is threaded and about 6mm wide. There's then a screw
inside it which bleeds the rad - which is the bit that's broken.
Does anyone have any ideas of some sort of radiator valve specialist as at
the moment i'm starting to think that I might end up having to
get a new radiator to replace one that's relatively new???
Cheers.
Dave Liquorice
Side as in one of the large faces that face the room or wall or side
as in end? Though I don't think it matters the ...
There's then a screw inside it which bleeds the rad - which is the bit
that's broken.
.... screw valve part is probably common between all the valves. As
you have the rad isolated take the valve out and have a look at it. I
suspect it'll be square ended (approx 5mm) with a threaded section
then a point. I'd expect the pin from any bleed valve to fit.
This doesn't fit with the housing size you've quoted though. A
picture paints a thousand words, pop one up on the web somewhere.
Roger Mills
sheared off and started a slow dripping leak from the rad. I've
isolated the rad but it's now unusable until I've got a replacement part.
and the soonest they can come out is Thursday (time wasters) I know
it, so I'm trying to get it myself as it would be cheap and easy to
fit anyway.
to be the ultimate unforeseen challenge. Yesterday, in my lunch break
I went to...
of them has the part.
Centerrad and it was fitted about 5 years ago. It's a traditional
single rounded top style and the bleed valve is on the right hand
side, sort of offset at angle (looking down on it). The full part (a
sort of bolt that unscrews) is about 10mm long and is threaded and about
screw inside it which bleeds the rad - which is the bit that's broken.
as at the moment i'm starting to think that I might end up having to
Cheers.
Try http://www.bes.co.uk/ - and type "air vent" (without the quotes) into
the search box, select the first item, and scroll down to find something
which looks like your required bit.
Chances are that the thread on the outer bit is 1/8"BSP (which is actually
nearly 10mm in diameter). I'm not quite sure which dimensions were 10 and
6mm respectively in your description.
Cheers,
Roger
______
Email address maintained for newsgroup use only, and not regularly
monitored.. Messages sent to it may not be read for several weeks.
PLEASE REPLY TO NEWSGROUP!
Roger Mills
Problem is, that's the bit that's sheared - so he can't get the pin out!
Cheers,
Roger
______
U
Usenet Nutter
went to...
them has the part.
Cheers.
Is it like this ?
http://img.photobucket.com/albums/v487/molley/CHDrain/IMGP0112.jpg
RedOnRed
Thanks for all of the replies and sorry for the delay getting back. I've
been unable to take and post pics at work.
Here's a few pics...
The radiator...
http://i1001.photobucket.com/albums/af135/Red0nRed/IMG_0870.jpg
Side on view of the radiator....
http://i1001.photobucket.com/albums/af135/Red0nRed/IMG_0871.jpg
Bleed valve on a 5 pence piece...
http://i1001.photobucket.com/albums/af135/Red0nRed/IMG_0869.jpg
http://i1001.photobucket.com/albums/af135/Red0nRed/IMG_0868.jpg
I only had the rad installed 5 years ago but Plumbcenter seem to think that
it's not made any more.
Any advice greatly appreciated.
Bob Minchin
The radiator...
that it's not made any more.
This air vent does not look like it has a standard BSP thread so might
be difficult to find a new one to fit.
Put the old one back with some PTFE tape
If you look here http://www.bes.co.uk/products/114.asp
at part no 16383, you can fit a compression TEE in the pipe alongside
the valve. Put the branch facing upwards and insert the air vent.
hth
Bob
RedOnRed
Bob Minchin said:
This air vent does not look like it has a standard BSP thread so might be
at part no 16383, you can fit a compression TEE in the pipe alongside the
hth
Bob
Thanks for that.
The part that you mention above is 15 or 22mm I think in width of the screw
and looks similar to the ones I was being shown over the counter
at BSS and Plumbcenter. The one I have is only about 6 or 7 mm across where
the thread is.
Dave Liquorice
I was being shown over the counter at BSS and Plumbcenter. The one I
have is only about 6 or 7 mm across where the thread is.
Did you have the bust one with you when you did your trawl around the
stores? That BES link has three sizes of screw in air vent, 1/8 1/4
and 1/2" BSP. I'd ceratinly compare the 1/8" with something "6 or 7mm
across".
Got to admit that the thread doesn't look the right shape for BSP but
it could be full of sealing gunk and I'd be surprised if it really
wasn't a standard (if uncommon) part.
Dave Liquorice
Having seen the pics it would be tricky but not impossible. At least
the pin is soft so you can drill it with relative ease unlike a
hardned steel bolt. B-)
Wonder if the JML screw extractors that are on offer in Homebase at
£4.99 (normally £9.99) would work? I wouldn't pay £9.99 for 'em but
£4.99 is worth a punt.
Bob Minchin
RedOnRed said:
Thanks for that.
screw and looks similar to the ones I was being shown over the counter
Please re-read my suggestion.
I am suggesting to abandon the existing bleed location and fit a new one
in the feed pipe adjacent to the radiator with an upward facing T and
the air vent which fits into a compression joint in place of the olive.
If it turns out the thread is BSP (and that would be normal) then on the
same page of the BES catalogue, you will find 1/8 BSP air vents which
should fit into the radiator.
Bob
Bob
Bob Minchin
Mike said:
But how will that enable him to bleed out any air that accumulates at the
top of the radiator?
Fair point! I had assumed top entry radiators like the ones I have
I'll crawl back under my stone now
Bob
RedOnRed
I've got the E-on engineer coming round tomorrow whom I don't have much
confidence in at the best of times. I know the part's not
available but i'm expecting the engineer to try and order it anyway, which
will probably take ages to confirm what I already
know.
Hopefully he'll just end up replacing the actual radiator sooner rather then
later. If all else fails i'll probably end up getting a new rad'
myself. A 600 x 700 single one is only £20 something from Wickes with a 10
year guarantte and it's bound to be better then the
one i've already got. It's actually starting to feel like the easier option.
Fortunately, we haven't got the heating on at the moment. Anyway we'll see
how we get on tomorrow with E-on.
zeg
I need the exact same part. Any luck?
Is the part we need a radiator bleed valve 1/16"bsp threads?
