Quarry tiles for hearth
W
White Rabbit
x-no-archive: yes
I need to replace old broken red (quarry?) tiles in hearth of open coal
fire. They are rather thick: seven-eighths of an inch thick. Do I have to
use some special tiles that are heat-resistant (to withstand the occasional
hot coal that may fall from the fire) ? Or can I just use any old 'quary
tiles'?
Thanks for any help.
L
Lee
You can get any 1" thick red quarry tiles from most tile suppliers (Ruabon
and the most common Welsh quarry tiles http://www.dennisruabon.co.uk/) and
these will be more that sufficient for a heath and will withstand the
temparature easily.
The only thing to watch out for is that modern 1" thick quarrys are 8" x 8"
whereas the older ones were 9" x 9"
Lee.
W
White Rabbit
x-no-archive: yes
temparature easily.
Lee.
That's reassuring, thanks. The tiles that need replacing are 6" x 6" -
guessing at 1950 vintage.
asher
Watch out for metric tile sizes when you're getting replacements. Some
'6"' tiles I bought to repair some outside quarry tiling at my house
were actually 150mm x 150mm (6 inches is 152mm). In my case I just used
4mm tile spaces when laying them instead of the 2mm used originally so
that the new tiles would line up with the old pattern.
Asher.
quarry tiled hearth - how to bed them? 0
Quarry TIles 4
quarry tiles 2
Body filler for quarry tiles ? 3
refurbish quarry tiles 5
Fixing quarry tiles 2
Coating quarry tiles 2
Elusive Quarry Tiles 3
