PVC pipe
Molly
Hello All:
I am looking for a place to purchase (or create) 2 inch scheule 40 pvc pipe, each piece two foot long with one end having a belled end. Any ideas where I can find this? Any help would be much appreciated.
Thanks.
H
HerHusband
Molly,
schedule 40 pvc pipe, each piece two foot long with one
You can find standard PVC pipe (the white stuff) for DWV (drain, waste,
vent) at most home centers (Home Depot, Lowes, etc.). It normally comes in
10 foot lengths, just use a saw to cut it to whatever length you need. Many
places also sell smaller precut lengths (typically five feet) for smaller
repair projects. Standard PVC pipe doesn't have belled ends, you use
coupling fittings to join the sections together.
If you're not using the PVC for plumbing, you can find grey PVC electrical
conduit in most home centers also. It also comes in ten foot lengths, but
the conduit is usually flared on one end so you can join sections without
additional fittings. You could easily cut it down to a two foot length if
that's all you need.
Hope this helps,
Anthony Watson
Mountain Software
www.mountain-software.com
PVC pipe 0
PVC pipe 12
pvc pipe 11
Painting PVC pipes 3
Painting PVC pipe 5
PVC pipe repair?? 2
Cracked PVC Pipe 5
PVC pipe fittings 4
