punching bag
E
Eigenvector
A lot of hits if you google this, but a serious lack of detail.
Any reason why you couldn't hang a 100+ lb punching bag from a 2x8 rafter?
I can see it holding the weight as a static load no problem, but wobbling
around and such as it's hit might change things.
Tony Hwang
My kid uses a free standing one on the floor. He does kick boxing/Jujitsu.
C & E
Why chance it. If the ceiling is open I would opt to bridge to the adjacent
joists on either side with some 2x8 stubs to distribute the weight and add
stability as well.
Proctologically Violated©®
Agree w/ the cross bracing, altho there are better and worser ways to do
this.
If you have access to the joists, get a piece of 3/4 ply, or some 2x4s and
attach to the *top* of the joists, and hang the bag from the middle of this
piece of added wood. This way you need relatively small screws, with minimal
penetration to the joists.
This will distribute the load AND stabilize each joist.
Most important is hanging the bag from a suitable spring.
Weider, Everlast et al should have these springs, or you can improvise,
actually tailoring heavy duty springs by putting them in series/parallel.
The total extension of the springs, about 6-8" long, should be about 2" or
so, to reduce the percussive load on the joists.
Mr. P.V.'d (formerly Droll Troll), Yonkers, NY
Stop Corruption in Congress & Send the Ultimate Message:
Absolutely Vote, but NOT for a Democrat or a Republican.
Ending Corruption in Congress is the *Single Best Way*
to Materially Improve Your Family's Life.
The Solution is so simple--and inexpensive!
entropic3.14decay at optonline2.718 dot net; remove pi and e to reply--ie,
all d'numbuhs
E
Eigenvector
this.
this piece of added wood. This way you need relatively small screws, with
minimal penetration to the joists.
That's a pretty damn good idea. I have plenty of left over plywood from the
basement floor removal so doing something like that will be a snap.
Have fun!
Don't forget the springs.
Altho the joists are likely not to be in mortal danger from springless-ness,
you might induce wall/ceiling cracks from this kind of percussive load.
Along those lines, consider matting/padding on the attic floor, to dampen
the percussive loads of all the inevitable jumping around. Sam's/Costco
have a kind of rubber-interlocking colored matting, relatively cheap, altho
I think multiple layers of thick-pile carpeting would do well also.
Another and perhaps better strategy is to take plywood/floorboards raised up
on 2x4s (wide-side down, if you prefer), but deliberately spaced wide so
that the wood has some spring to it.
An even more elegant strategy, and not that complicated, is to create a
"floating floor", with supporting 2x4s (mini floor joists, if you will,
traditionally spaced) mounted on die springs. Then carpet this. Splinters,
donchaknow.... :)
I use a variant of this system for weight lifting, for shock absorption of
the lowered bar/weights. *Very* effective, perty elegant.
The 2x4s would actually be drilled to accept the die springs. Easy to do.
Die springs for this application would run between $3 and $5 each, you might
need about 4-8, depending on the area around the bag.
Unfortunately, some experimentation w/ spring length and stiffness will
likely be required. Most likely the springs I use for my weight ditty would
not be optimal for your floor, but they would still work.
Some hardware stores (mebbe even goddamm HD) have a nice selection "stock
springs", some of which are pretty heavy duty, and might suffice for this
application. You're looking at springs approx. 1" in diam, 2-4" long, with
a wire size of about 1/8"--perty thick, for spring wire.
If you decide to go this route, I can help you experimentally determine the
working spring size,without it costing you a fortune.
And, a nice hardware guy would let you return the springs you don't use, if
you tell him up front what you're trying to do.
Which is perhaps the only redeeming thing about goddamm HD, returning crap
w/ impunity. :)
Other substitutes exist: urethane springs/pads, HVAC isolation pads, often
made out of rubber/cork, etc.
Much more than you wanted to know, I'm sure. :)
all d'numbuhs
Just Joshin
I was thinking the same thing, but I have 2x10's. I came to the
conclusion when I install one, I will put bridging around it.
tom @ www.Numerology-Readings.com
this.
profi boxsack
all d'numbuhs
My ceiling is 6'6 so I am a little stuck. I won't lower myself to using a free standing bag but I still am not able to hang a bag. My walls are brick and like cardboard so no wall mount works.
I'm looking for a punching bag stand that will still hold the bag high enough for me (I'm 5'9) but won't be too big for my 78-79 inch ceiling :(
Anyone know?
jagga009
