Proper way to attach fascia boards
dynamorph
Usenet Archive
I am building a porch. The roof decking is 1" wide boards extending 14" out from each side (gable ends). I'm about to attach 1x6 fascia boards, and am wondering if it's ok to nail them into the end grain of the 1" board, flush with the top of the roof planks. The purpose is not only appearence but also to keep the roof boards in a straight line and prevent them from warping. I will also add some lateral support 2x6 attached to the fascia and to the inside rafter.
Thanks,
Goedjn
Usenet Archive
Thanks,
I'm going from memory, but I think the normal way to do that is to have built a sort of ladder-shaped assembly out of whatever your rafters are made of, so that there's an actual rafter out there under the end of the decking. If it's too late to do that, or the design makes it undesirable, I'd at least run a board flat on the underside of the decking and attach the deck and then barge-board to that.
IMO, 1" planking is too thin to be end-nailing into.
Tom (archive)
Usenet Archive
Jeff wrote:I am building a porch. The roof decking is 1" wide boards extending 14" out from each side (gable ends). I'm about to attach 1x6 fascia boards, and am wondering if it's ok to nail them into the end grain of the 1" board, flush with the top of the roof planks. The purpose is not only appearence but also to keep the roof boards in a straight line and prevent them from warping. I will also add some lateral support 2x6 attached to the fascia and to the inside rafter.
I've seen the rake/fascia board
rabbetted to accept the roofboards. Then you can drive nails from above, with some support for the rakeboard, of course. Tom
Tom (archive)
Usenet Archive
I've seen the rakeboard rabbetted to accept the decking. Then nail from the top. Tom
lisac
