Problem with radiator tails
DavidM
I'm having problems with a new bathroom radiator/towel rail in getting
the tails to seal properly into the rad. The tails seemed quite a
loose fit and despite a fairly liberal application of ptfe tape there
is still a bit of weepage which is now starting to stain the floor
tiles, so I need to do something about it. Unfortunately the floor has
electric underfloor heating, embedded in some (now solid) latex goo,
plus the tile cement, and the pipes to the rad are pretty well
immovable. I can get the rad off ok, but will need to ensure that the
tails, when refitted, project exactly the same amount.
Any suggestions on sealing the tails - Fernox LX, Plumers Mate, Boss
White, yet more ptfe, etc?
Thanks for any advice.
David.
Cicero
David.
You could use old fashioned hemp + Boss White instead of the PTFE tape.
Hemp has more 'body' than tape.
Cic.
John Stumbles
Or new-fashioned stuff that's like dental floss but thicker and made of
some combination of nylon and PTFE
CJF
Last time I did this it was new tails into 30 yr old rads (thermostatic
valves), and I used what I had to hand - hemp and LSX. This old/new
combinarion was easy to use, and worked a treat. Hemp is very good at gap
filling in threads, so might be good for your problem, and LSX is clean and
effective as a sealant.
Charles F
Andrew Gabriel
When I put my radiators in, I used the white PTFE. Started off with
10 turns. If that didn't tighten up before the tail screwed all the
way in, I'd strip it off and do 12 or 15 turns, depending how far
off it was. They were then all air pressure tested for leaks before
the system was filled with water. I don't think I had to reseal any
of the tails (only some of the compression fittings).
sm_jamieson
Get some of the gas ptfe tape - its much thicker.
Simon.
Bob Mannix
I always do a number of turns, wind it in until tightening, then remove and
ADD more turns on top (the first ones having been driven into the threads.
Never had a leak yet.
DavidM
David.
Thanks for the suggestions. Picked up some hemp from the plumbers
today, will have a try with that and Fernox when I go back next week.
David.
