thomasb369
We recently moved into a 75-year-old home which has a newer,
energy-efficient gas forced air furnace. The ductwork and venting are
much older than the furnace...I'm guessing 1950's or 60's. The heat and
intake vents are cut into the baseboards along the wall, perpendicular
to the floor.
The problem is that when the furnace is not running, we get cold drafts
of air through both the cold air intakes and the heat vents, coming up
from the basement I suppose. The breeze is fairly strong...it will
cause a piece of paper to flap out if held in front of the vent.
Surely there is some way to prevent this? Some gadget which closes off
the vent when the furnace isn't blowing? If we remove the vent covers,
there is nothing between it and the big hole into the ductwork. Should
there be?
Thanks in advance for any help you can provide.
Tommy
to the floor.
there be?
Tommy
