pH Neutralizer
N
None
Hello,
I live off city mains water with a pH of around 6.7 and very low
alkalinity (46ppm). The hardness is between 20-30 mg/L, and no
iron/manganese problems. The thing is that my skin just can't take this
type of water, and I presume the pH can go lower than 6.7 due to the
low alkalinity present. I had a neutralizer installed and fitted, but
the pH seems to be all over the place
How much hardness should be added to just neutralize and not go higher,
or should I even have bothered with this pH unit at all in the first
place. The water is terrible now, slimy even.
N
None
None said:
Hello,
Please Help!
Neutral Woes 9
to find a neutral 0
Red neutral? 2
? re neutralizer cartridge 0
Calcium Chloride - neutralize 4
neutral and ground 8
Neutral cable 18
Dunsley Neutralizer ???? 6
