Peeling Paint on Patio
denregan54
I have a small concrete patio area ( 3Mx2M) which I painted with a
'Garage Floor Paint' a couple of years ago. Not a Good Idea !
Moisture has caused patches of the paint to flake off leving unsightly
gaps.
Problem One : What is the best way to remove the rest of the paint ?
Problem Two : My preferred option is to tile this small patio - what
sort of tiles should I be looking for and is it a difficult job (
Cutting problems etc )?
I live in Southwest Scotland so frost in winter could be a factor.
Any ideas much appreciated.
Rod
gaps.
Buy or hire a high pressure washer
bigcat
gaps.
What possibility shall we propose for peeling purple paint on Peters
patio?
Best way: vortex whatnot as used to clean paint off brickwork
Quick cheaper but not as efective way: pressure washing
Cheap way that only makes it good enough to repaint: wire brush
floor tiles
Important not to leave any gaps under the tiles, as you dont want them
to fill with water and freeze.
NT
David
gaps.
1) Use a pressure washer. Paint should lift off easily!
2) Have a look for quarry tiles. I've used these on door steps and landings
exposed to frost without any problems. Make certain which ever ones you go
for are frost resistant. I also made certain that they were well bedded in.
There are numerous other types available which will also do the job. Bear in
mind though that tiles can be slippery if wet / leaves lie on them (not to
mention frost)!
good luck
David
Peeling Paint on Patio 3
Peeling Paint 0
peeling paint 2
bubbling / peeling paint on radiator 4
Peeling Paint 2
Paint Peeling 11
Peeling paint on wooden window frames 11
when paint peels... 2
