Patio door rough opening
W
Walter Cohen
I want to have my sliding patio doors replaced.
I am fairly certain that the doors there now are the standard size (72" x
80").
I know little about construction and door/window sizings, rough openings,
etc...
The standard sized Andersen doors I want to get specify a rough opening of
71 1/4 x 80 is needed.
Question: the frame for the doors that I have now measure exactly 72 x 80.
Will the standard sized Andersen doors (above) fit correctly? What needs to
be done to the opening?
Thanks,
Walter
ameijers
80").
etc...
The odds are it will fit fine- a six-foot slider is probably the most common
size in north america. Are you planning on installing it yourself? If so,
and you haven't done it before, recommend buying one of the DIY books at
the big-box- the pictures will explain better than words ever could. Note
that you will need at least 2 strong guys to assist- these suckers are
heavy, and Anderson will be heavier than most. (wood frame, right?) If you
are hiring it done (highly recommended the first time, as a learning
experience), the installer will know how to shim and square appropriately,
and most important, how to flash it appropriately. Do NOT remove the
horizontal shipping strip in the middle until the door is in place. If your
rough opening is a hair too small, there are ways to fine-tune reality, but
you need to know what you are doing. Any adjustments over 1/2 or 3/4 or so
to the opening usually mean reframing the wall a little. If your hole is
slightly too wide, it just means adding a little wood to one or both sides,
and inventing a way to make the outside trim look right, if it doesn't cover
the old hole in the siding or brick or whatever.
aem sends....
twfsa
I replaced the slider in my kitchen with a Jeld-Wen swinging patio, did not
have to make the opening bigger, but I did remove the trim around the inside
to measure and make sure it would fit.
Whats the size of the Andersen doors, the sales people should be able to
tell you that, at least the brochure should say!
Tom
twfsa
This is not a Do it yourselfer job.
Tom
common
your
but
sides,
cover
aem sends....
H
Harry K
Tom
It most certainly is IF the DIYer knows what he is doing. You are
correct that the OP doesn't have the expertise to do it.
Harry K
twfsa
Well I hope a person would know what they are doing, these doors are
expensive, get it in there crooked then you have to hire someone to try and
fix your mistakes, provided you didn't break the door casing, or ruin the
track,
My .02 cents worth.
Tom
H
Harry K
track,
My .02 cents worth.
Tom
So you somehow missed the meaning of a simple 2 sentence post?
Harry K
N
NickySantoro
80").
etc...
Thanks,
Walter
You should be fine. I did one sometime back and the physical
dimensions of the unit were a bit under the RO specified, I assume to
allow for shimming. Previous responders are correct in stating that
the units are heavy. You will need help to lift and maneuver it.
E
evodawg
80").
etc...
to be done to the opening?
Thanks,
Walter
It should be no problem. BTW Anderson sliders and french doors come in
pieces and you have to install the components. Not like pella or others. I
have installed many and you can easily do it by yourself depending on your
knowledge.
Rich
