Painted tile floor - how to resurface?
N
no_junk_mail
My girlfriend has a Saltillo tile floor in a 10x10 sun room - a few years
ago, her ex spilled a bucket of paint on the floor - they decided to paint
the entire floor with a water-based latex paint - their two dogs stayed
there most of the day over the years - 7 years later, it looks terrible -
big surprise, huh? She needs to do something to the floor before she puts
the house on the market - I think removing the paint from the tile and grout
is going to to be way too much effort, if it's even possible. I was
thinking that some kind of coating, maybe like they use on the concrete
floors in a garage, might be a potential solution. If so, what would I need
to do to prep the existing surface to prepare it for the coating? I'd
appreciate any other suggestions - I was thinking that a laminate floor
might work, but the tile surface is pretty uneven.
Thanks!
Todd H.
Oy what a mess.
It's a small room is the good news. I'm guessing that removing the
existing tile replacing the flooring in there with laminate Pergo type
stuff, or something of that nature might be (sadly) the quickest fix.
Cleaning up that tile even if it is possible will take longer than
scraping it out and slapping down some laminate would. Laminate floor
directly over an uneven surface is gonna be noticeably goofy when
walked upon I'm guessing.
N
no_junk_mail
Yeah, I knew the laminate idea would be a longshot - take up the tile - not
somethig I'm gonna tackle - carpet might be a solution??
Todd H.
Good point. An area rug might do wonders. Imagine how pissed the
buyers will be when you take that baby with ya.
Dunno if you can do installed wall to wall on such a surface either
because there's really no way to deal with the tack strips?
Todd
SQLit
Thanks!
I know that pros use pressure washers to remove the coatings from Saltillo
tile for refinishing.
It is a mess but it does work. Need lots of pressure and volume and it will
take the better part of a long day to get it off. Then let dry really well
and re-seal the tile.
Lots of plastic on the walls to protect everything and take the outside door
off. You will have a river running before to long.
G Henslee
Just clean it good and repaint it.
deans
Greetings,
Purchase a $4 gallon of a dark brown off-tint paint and roll it (2
thick coats) with a $1 roller. This won't "fix the problem" but the
results might be worth $5 to you. After the paint is DRY put down an
area rug. This will protect the paint.
Take the 6 hours and $200 you saved elsewhere.
Aug 5th 2006 - take an hour off and spend $46 to celebrate
Aug 5th 2007 - take an hour off and spend $46 to celebrate
Aug 5th 2008 - take an hour off and spend $46 to celebrate
Aug 5th 2009 - take an hour off and spend $46 to celebrate
Aug 5th 2010 - take an hour off and spend $46 to celebrate
Aug 5th 2011 - take an hour off and spend $46 to celebrate
Invested at 10% you could spend $46 per year during one of those hours
you saved every year for six years.
If this all sounds silly to you then use the 6 hours and $200 you saved
to fix something you find wrong with your new house.
Hope this helps,
William
PS: Don't let the dogs back in if you can help it.
N
no_junk_mail
The dogs have moved on to the big dog house in the sky . . .
Todd
You can glue carpet tackless rod (semi-humorously often called "Smoothedge") to most domestic floor surfaces. You might get away with any of the "No More Nails" glues, but the special glues sold for the purpose (also in cartridges suitable for a mastic "gun") cure much faster. But I have found them much harder to use than thick PVA!
