Painted 32mm waste
JohnW
Have a leak on a solvent weld 32mm bathroom basin waste. The existing
pipe has been painted. Does anyone have a recommendation on which will
be easiest/work best for replacing the bad pipework and connecting to
the painted bits - solvent weld, compression or push fit? Is it best
to remove the paint first or does this action mean that the scratched
area is worse than the paint?
Thanks for your help
John
The Natural Philosopher
John
replace the lot and repaint fresh. Its cheap enough.
paint must be cleaned off pipe to be welded.
The Medway Handyman
You have to remove all the paint whatever solution you choose, no easy way
around it - or cut back to unpainted pipe. Best chance [1] of removing the
paint is boiling water, if possible.
[1] Not much of a chance, its a bugger to get orf.
meow2222
Does a steel scourer not work? Another option is caustic soda.
NT
Andrew Gabriel
A piece of sandpaper wrapped around the pipe would take it off.
Note that, if it's been painted correctly with just oil-based
gloss topcoat, you won't get all the paint pigment off as it
dissolves into the plastic surface.
Y
YAPH
Push fit won't connect to solvent weld: they're different sizes. So
the choices are solvent weld or compression. Which is easier and more
suitable? Either way I'd remove any bulky runs of paint. Emulsion
scrapes off easily, oil-based is harder to shift. If you're going for
solvent weld you should scrape the paint off back to the plastic. Doesn't
have to be perfectly clean but you want the cement to bond the plastic,
not the paint.
