Paint Won't Dry
Photon713
Evening, all...
I have painted some plastic stuff with a craft paint specifically for
plastic. However, after 1 week it has not dried. It is still tacky to
the touch. I am considering using a clear polyurethane over the
paint in hopes that it might leave a dry surface. Can anyone
recommend this or have another approach? The paint will
ultimately be up against clothing.
Regards...Bob
Pete C.
Photon713 said:
Evening, all...
Regards...Bob
Contact the paint manufacturer. Certainly putting a coat of a
potentially incompatible product on top of a product that is already
known to have a problem is only asking for more trouble.
Pete C.
aenewhouse
jeffc said:
Do not do that. My only suggestion is to start from scratch. I don't know
what went wrong, but I do know it will be extremely difficult to figure out.
You're just asking for more headaches. Scrap it.
I agree. Adding another coat of almost anything on top of a non-dry
coat will only make things worse. Was the paint you used quite old?
I would try to scrape the tacky paint off if possible - see if mineral
spirits softens it, or maybe acetone? What is the solvent recommended
for cleanup? Anyway, when you start from scratch, I'd try newer paint,
a different brand of paint, or paint thinned somewhat with mineral
spirits (or appropriate solvent).
Sorry and good luck,
Andy
m Ransley
Your paint is defective likely the driers are missing, best is remove it
if it wont dry in a warm dry environment.
Paint won't dry - still sticky 7
Drier Won't Dry 8
PLASTER WON'T DRY 4
Varnish won’t dry 5
Danish oil won't dry (!) 2
Drier Won't Dry - Part Duex 9
Maytag Dryer won't Dry 5
Jet Dry won't dispense 6
