paint peeling off walls
SamanthaBooth
I have just removed the wallpaper and lining paper from two rooms. Under it
all someone has painted the walls, all of them partition walls and they look
like cardboard to me. Very soft walls and easily damaged. I dont know the
material used.
However some of the paint has peeled off and I tried a watered down coat of
paint on them today to see what it would look like and its very noticable.
There are lots of areas, albeit only small, where the paints come off and
its down to the board.
Would some kind of polyseal help to cover up the missing paint etc. It isnt
deep enough really to warrant using filler. But does anyone know of a
solution or product I can use to make it look better.
Thanks again
Phil L
Under it all someone has painted the walls, all of them partition
walls and they look like cardboard to me. Very soft walls and easily
damaged. I dont know the material used.
coat of paint on them today to see what it would look like and its
very noticable. There are lots of areas, albeit only small, where the
paints come off and its down to the board.
It isnt deep enough really to warrant using filler. But does anyone
know of a solution or product I can use to make it look better.
Thanks again
It's plasterboard that hasn't been plastered and you are now seeing one of
the reasons why it's a bad idea to tape and fill rather than plaster a PB
wall - the other major PITA is trying to strip wallpaper from a wall like
yours, put up by some innocent ignoramus who didn't realise that the wall
would now require demolishing should anyone down the line decide that they
wanted to change the decor.
Get it plastered, anything else is a botch.
SamanthaBooth
I didnt know it was plasterboard. I thought PB was light in colour and not
darkish like this stuff. It just looks like cardboard lol.
As some of the walls are painted is it OK to plaster over this?
Dave Liquorice
isnt deep enough really to warrant using filler. But does anyone know of
Two solutions:
1) Remove all the paint.
2) Wallpaper over lining paper.
You'll never be able to fill and/or feather the edges well enough for them
not to visible under just paint.
George \(dicegeorge\)
what about glueing very thin plywood sheets on to it-
how much would that cost?
or sheets of hardboard,
or something else
so the wall is not so soft and less damagable..
George
material used.
Thanks again
Polyfilla is ok to use for such a job.
Buy the ready mix stuff and apply with a 6" blade,the type with wooden
handle ..
Then put some filla on the scrapers edge and sweep the blad at an angle over
the imperfections imperfection.
You'll be suprised how much it actually wors well without sanding providing
the angle of the blade is kept right
The Natural Philosopher
It is, The other technique is to fill any dents and line the lot with
lining paper, and paint that.
Dave Liquorice
Buy the ready mix stuff ...
Bought some of that as I thought it would better for small filling jobs
rather than trying to mix up a teaspoon full of ordinary. Trouble is the
stuff I have has some fine grit in it so you can't feather it out
properly. The dry powder is *much* smoother.
Pete C
Does the existing paint have a texture or is it fairly smooth? If the
latter it gives you a much better chance of success, as there won't be
a marked change between previous and newly filled bits.
I'd try a sample with ready-to-use '1 part' plain white wood filler
and a sanding block, if a _little_ water is added to the filler it
makes it easier to spread thinly.
Also I found shining a torch on the wall at a low angle helps show up
any uneveness round the edges of the filled patches
For doing a lot of this a random orbital sander connected to a hoover
is the way to go, a long washing machine outlet hose duct taped to the
sander and hoover makes things easier.
cheers,
Pete
SamanthaBooth
isnt
cheers,
Pete
Thanks for the advice
i am going to fill and then put up lining paper.
i am off to b&q in the morning, there is also a crown decorating shop
nearby. What filler is the best to use for such a job, I have a lot of small
patches to use.
Thanks again
George
cheers,
Pete
patches to use.
Thanks again
Mangers polyfilla
Pete C
patches to use.
Just normal ready-to-use filler in a tub, look for something 'easy
sanding' as some are cement based and will set like rock!
The decorating shop will be able to give good advice, for the small
extra they may charge for a tub of filler it'd be well worth going
there.
If you try painting a sample over some filled bits and don't like it,
you can still just paper over it.
cheers,
Pete.
Stuart Noble
there.
cheers,
Pete.
Not being pedantic but "easy sanding" stuff in a tub doesn't normally
give as smooth a finish as your bog standard Polyfilla or own brand
equivalent "interior filler".
You can fill dents in the lining paper afterwards as well. However
careful you are, there are always bits you miss and the paper highlights
them a treat
Pete C
OK Dr Pedant ;) any _sandable_ filler.
In any case the decoraters merchant can advise the OP.
them a treat
Were you dozing in 'wall filler 101' classes? :)
cheers,
Pete.
stuart noble
They're all sandable but the lightweight stuff for deep filling doesn't
give a good enough finish to paint IME.
Totally asleep I imagine :) What did I miss?
