Oven door hinges locked in transit position. Won't unlock.
F
Fred Phase
I just thought I'd clean the oven door of my Hygena Diplomat. Bad
move.
The door removes by lifting some catches on the hinges and closing the
door. Instead of closing it lifts to allow removal. So far so good.
The problem comes when I am cleaning the removed door I accidentally
push the hinge. It closes and clicks in a fully retracted position,
which I assume is for transit or something.
I am normally quite good working these things out but this time I'm
stumped. There just doesn't seem to be any way to unlatch this hinge.
I have removed it from the glass door completely to have a closer
look. It's made by a company called "Nuova Star".
They have a website
http://www.nuovastar.com/e/company.html
But no information on the website on how to unlock locked hinges. From
what I can tell the hinge I have is on this page...
http://www.nuovastar.com/e/catalogo_3_en.html
And is model HE1S - Mod.086.
If anyone has experience with these hinges and knows how to unlock
them I would much appreciate it. Thanks
Fred.
BigWallop
move.
They have a website
Fred.
From the picture, it looks like there is a spring loaded lock within the
long arm section that, when closed, locks into the little notched valley on
the small section. You may have to pull out the spring loaded bar to allow
it to release from the notch.
F
Fred Phase
Yes, that fixed it. As a always the case I figured it out 10 minutes
after posting!
In case anyone else gets into the same pickle, this is how to fix
it...
1) Grip hinge assembly in a vice between the big spring and the arm
that holds it, but not across the arm as this will deform it. This
should rest on a ledge on the arm alllowing downward force.
2) Apply a flat-blade screwdriver to the ping at the end of the spring
loaded lock. Press the pin to relieve the pressure on the hinge.
3) Pull the hinge out, or prise it from the back until it starts to
move.
4) Extend the hinge as far out as you can.
Hope that helps someone out there :)
mjc
Same problem, many years later?
This sounds like the problem we just encountered after replacing cracked glass on our GE Profile oven door. Unfortunately the links to nuovastar.com are now broken (nuovastar.it works but it has no documentation for its hinges, so I have no way of knowing if we have the same hinge). Our hinge has the large spring outside the long metal box, and a smaller-diameter spring inside - partly exposed by a trapezoid-shaped hole. I'm less handy that Fred. I can clamp the hinge down (1), but where do I press the screwdriver to release the locked hinge? Many thanks to anyone who can help,
Michele
Again, same problem years later. My hinge type is a model 88. Didn't get any help from the product web site.
Followed Fred's method. Clamped (carefully) the hinge in a workmate so that I could get at the spring lock pawl on either side of the hinge body. Then, pushed the pawl back usin ga screwdriver on each side of the hinge. When it is fully retracted, then you can pull the hinge out. Remember to push the safety catch down to prevent it springing back into the locked position. Had to do this twice before I succeeded and got the door back on the oven.
