Outside Tap...
troubleinstore
I wish to put an outside tap in my front garden.
The nearest water supply is to the bathroom which is situated between the front and back bedrooms upstairs, so the pipe
for the tap would run under the floor in the front bedroom, through the outside wall and then down to the tap.
Can I do this using plastic water pipe with a shut off valve under the floor in order to turn the water off in the
winter months.
Your helpful comments would be most appreciated.
TIA
troubleinstore
http://www.tuppencechange.co.uk
Personal mail can be sent via website.
Email address in posting is ficticious and is intended as spam trap
View my items on eBay:-
http://cgi6.ebay.co.uk/ws/eBayISAPI.dll?ViewSellersOtherItems&include=0&userid=yorkie_8&sort=2&rows=25&since=-1&rd=1
V
Vortex
winter months.
I imagine you may want mains water pressure in the garden. If yes, is it
mains pressure in your bathroom?
David
troubleinstore
David
Thank you David for bringing it to my attention. Yes, it is mains water into the bathroom and yes it is for the garden.
At the moment, I have to run a hose pipe from either the kitchen in the back of the house or the outside tap in the back
yard through the dining room, lounge and then through the lounge window.
The front of the house faces onto a field with a path at the bottom of the garden. This is used by locals and is about
43 feet from by house wall.
I can imagine that a white or gray plastic pipe or even copper may look odd anyway.
troubleinstore
Z
zaax
odd anyway.
Normal garden hose under a few inches of soil seems to last[1]. And as
for the vandals if they don't see it they don't touch it.
[1] Hoses expand & also UK frosts don't normally go more than an inch or
2.
Outside Tap 24
Outside Tap 9
Outside Tap 27
Outside tap question 1
Dribbley Outside Taps. 1
outside tap problem ? 5
Outside Tap Help 5
fitted an outside tap.. 7
