Odd wiring.
  • Thread starter The Medway Handyman
  • Start date
The Medway Handyman
Doing various jobs at a lady's house, one of which was to replace the
pull cord switch in her en suite. Like for like, should have been simple.
Three story town house, en suite and common bathroom on the same floor.
One extractor fan vents both bathrooms via trunking.
The switch had failed mechanically as pull cords often do, but this one
was a weirdo.
Two cables coming in, both three core & earth, so red, yellow, blue.
The switch (Tenby MG888) had 4 terminals + earth.
Top left = COM, top right = N, bottom left = 1 WAY, bottom right = 2 WAY.
Never seen one of these before.
Cable 1 wired yellow to COM, red to 1 WAY, blue joined to blue in Cable 2.
Cable 2 wired yellow to COM, red to 1 WAY, blue joined to blue from Cable 1.
Terminals 1 WAY and 2 WAY are linked by a red cable.
I assume it's wired so that the switch in either bathroom triggers the
fan (which is on a timer).
Three visits to electrical wholesalers & a web search doesn't find a
Tenby MG 888 switch, so I've e mailed the manufacturers.
Not knowing how the switch 'switches' I can't figure out how it would
work or what alternative I can use if I can't locate a replacement switch.
This has even caused the knowledgeable & helpful Mr Wadsworth to scratch
his head!
Any thoughts?
Roger Mills
was a weirdo.
Cable 1.
his head!
Any thoughts?
Odd! Were the two blue wires connected to the neutral terminal, or just
joined together in fresh air? Was *anything* connected to the N terminal?
Does the switch have a neon light, which glows when it's 'on'? If so,
that might account for the need for a neutral.
Having terminals marked Com, 1-way and 2-way suggests that it's a
change-over - with Com connected to 1-way in one position, changing to
Com to 2-way when you toggle it. In that case, it's *very* odd to join
1-way and 2-way together, because that means that the switch in *on* in
*both* positions, so that toggling it has now effect!
Are you sure you have reported the wiring correctly? What, according, to
the owner, is it *supposed* to do, and what is the perceived problem
which caused her to ask for it to be replaced?
Cheers,
Roger
____________
Please reply to Newsgroup. Whilst email address is valid, it is seldom
checked.
Brian Gaff
Two switches, take the other one that works off and test it?
Brian
ARWadsworth
That is something we discussed over the phone.But Dave was not on site at
the time.
The Medway Handyman
Joined as in fresh air :) Chocky block.
Nope.
My thoughts exactly!
Pretty sure - I'll post a photo somewhere. The switch failed
mechanically & the light wouldn't come on - or the fan.
ARWadsworth
simple.
floor.
one was a weirdo.
WAY.
Cable 2.
Cable 1.
switch.
scratch his head!
Any thoughts?
I have to say that I still believe it is what I suggested when you phoned
me. It's a double pole pullcord switch. The reds have been linked up to give
a permanent live to the fan (not that that link is needed), the yellows are
the switched live and the blues in the strip connector are the neutrals.
http://s428.photobucket.com/albums/qq6/adamko2020/?action=view&current=TMHpullswitch.jpg.
O
Owain
O
Owain
Should be wired using a double pole switch.
http://groups.google.com/group/uk.d-i-y/browse_thread/thread/98f7dd24...
LIVE -------------- SWa Pole 1----------- LIGHT -- Neutral
                 |-- SWa Pole 2-----
                                   --SHARED -- Neutral
                                   --FAN
                 |-- SWb Pole 2-----
 LIVE -------------- SWb Pole 1 ---------- LIGHT  -- Neutral
if a timer fan then you will have an unswitched live to the fan as
well.
Owain
Double pole pull switch MK 3151 requires mounting block
http://www.tlc-direct.co.uk/Products/MK3151.html
Owain
O
Owain
http://s428.photobucket.com/albums/qq6/adamko2020/?action=view¤....
I agree. And the link between the two poles is needed to provide a
live to the right-hand yellow switched live.
Owain
Roger Mills
http://groups.google.com/group/uk.d-i-y/browse_thread/thread/98f7dd24859ce778/59046c4bcfbf94e1
|-- SWa Pole 2-----
-- SHARED -- Neutral
-- FAN
|-- SWb Pole 2-----
well.
Owain
That makes perfect sense! But, in that case, I wouldn't expect the 4
poles to be labelled Com, 1-way, 2-way and N [1]. Has TMH misead them?
[1] I'm not sure what I *would* expect to see, but not that!
Cheers,
Roger
____________
checked.
The Medway Handyman
O
Owain
Ta.  So how does that translate to wiring colours?
Red - perm live in, perm live to fan
Yellow - switched live to light, switched live to fan
Blue - neutral in, neutral to fan
RED -------------- SWa Pole 1-------YLW1---- LIGHT -- (neutral not
present at switch)
|-- SWa Pole 2----YLW2-----| (sw live to trigger)
|-----------------RED----SHARED (perm live to
fan)
FAN
BLUE ------------------CHOCKY-------BLUE-----| (neutral to fan)
Owain
O
Owain
Slightly amended so as not to linewrap. Still requires fixed font.
Note the N to the light is not present at the switch
RED ----------- SWa Pole 1----YLW1---LIGHT--> N.
|-----------------RED----SHARED (perm L to fan)
FAN
BLUE-------------CHOCKY-------BLUE-----| (neutral to fan)
Owain
jgharston
(snip Owain's diagram)
This is exactly why I wire up so there's exactly one
unambiguous cable at each switch/outlet/whatever
and do all the voodoo in junction boxes. Even
tho' it's depreciated, I've had too many calls
from people who've taken a switch or ceiling
rose off and can't get any further.
Or worse, "I joined all the reds, and all the blacks,
and all the greens, but when I try to turn the light
off the fuse blows"
JGH
ARWadsworth
simple.
floor.
one was a weirdo.
WAY.
Cable 2.
Cable 1.
switch.
scratch his head!
Any thoughts?
http://www.electrika.com/f/0550-legrand-w-10-11/#/182/
part number 0611 30
O
Owain
OK, I have located the switch Owain suggested.
It has L & N Supply at the top and L & N Load at the bottom.
So, do I wire it;
2 x reds to L Load, link to N Load, blues together, yellows to L & N Supply?
No, you put the supply in the Supply side and the load in the Load
side :)
RED ---------|--SUPPLY 1 LOAD---YLW1
RED ---------|--SUPPLY 2 LOAD---YLW2
BLUE --------|
BLEU --------|
Owain
Odd wiring? 18
Odd lighting circuit wiring 11
Ceiling light - Odd wire 9
Please ID another odd wire! 1
Odd question... 30
Odd taps 7
Odd question. 13
Odd project 13
