NovaTek MeterMatic Water Softener
Discussion in 'Home Repair' started by James, Nov 24, 2003.
  1. James
    James Guest
    It's using too much salt but I can't figure out how to set the
    regeneration for 2 people...
    I purchased a home with this water softener (circa 1994) and managed
    to find the user manual for it online at:
    http://www.usfwatergroup.com/pdf%20folder/Manuals/Novatek%20Logic%20Water%20Softener.pdf,
    however the manual doesn't cleary indicate how to set the regeneration
    for 2 people.
    Does anyone know how the black dial on the left works? The manual
    suggets that there are 2 independent settings that can be done with
    the dial, but I only see one way to adjust it.
    Thanks!
    James, Nov 24, 2003
