Hello:
Moved into a 30 yr old house that has the vertical T1-11 (I'm told that is what it is called) for the outside surface. Several pieces are damage, as well as some of the ends having soaked up water over the years, and should be replaced.
Guess there are several ways to go.
I can have vinyl siding applied.
Another possibility that I was wondering about is whether it is possible, or practical, to have the more normal/conventional horizontal wood board type of siding applied. Not sure what the correct term is (clapboards ?)
Any thoughts on this, particularly regarding whether it can, or should, be applied directly over the existing T1-11 ?
Would like to consider doing it without stripping the whole house. Also, I imagine it would provide a bit more insulation, and be a lot simpler and inexpensive to do it without removing the old T1-11 first.
Thoughts on ?
Thanks,
Bob
Thoughts on ?
Thanks,
Bob
