Moving a hot water tank into loft.
Colin Chaplin
Hey All
I've got a new house with a "Boilermate II from Gledhill Water Storage Ltd"
which resides in my upstairs airing cupboard. When your other half hoards as
much junk as mine, you need every spare inch of space, and when she spends
as much as she does, you need to save every penny ;-)
Therefore I was thinking about moving it directly up into the loft.
My plan of action was to stop the water, drain the system, 'unplug' from
mains, cut a hole in the loft above it then lift it up. Build a platform to
hold it (I presume it isn't light !) then simply extend the pipework up into
the loft. Easy.
Seems obvious. The only downside I can see is that there's a timer and
winter/summer setting which we only change occasionally so not a problem.
So why don't the builders do it, and is it something that I can ?
Thanks all
C.
Rob Morley
"Colin Chaplin" said:
Hey All
the loft. Easy.
An airing cupboard is useful, why not keep the junk in the loft?
Doctor Evil
Colin Chaplin said:
Hey All
Nice. A class act. I have the Gledhill Systemate.
A bad place to put it.
when she spends as much as
Stop her from wasting your money. Only give her 3/6d pocket money a week.
Very sensible.
then lift it up.
It is a matter of just extending the cables and pipes up above. Make sure
you insulate all the pipes to the Boilermate in the loft with the thickest
pipe insulation you can find.
When you refill make sure you put enough inhibitor in, which will be about 3
to 4 1 litre cans. Check with Gledhill. The installation instructions are
on their website.
Build a platform to
the loft. Easy.
Make sure the support can take the weight. You may want to install a small
rad in the airing cupboard. Have this taken off the flow and return pipes
from the boiler top the Boilermate, so it always works in summer and winter.
You may want to put a straight in-line thermostat valve in the cupboard,
running vertically just behind the door frame where it hinges, at about 1.5
meters from the floor. it is then easy to regulate. Or, strip off the
insulation of the Boiler flow and return pipes as they run through the
airing cupboard. This will keep it warmish in there. Make sure you seal
all the pipe and cables with silicon as they run through to the loft and
have twice the insulation thickness over the cupboard.
One point is freezing in the loft in winter. You want to install a frost
pipe stat on the return to then boiler. If the temp get below 1C or so the
boiler kicks in to maintain it above theta temp. In reality frost
protection may be unnecessary, as Gledhill thermals store are "very" heavily
insulated., so keep the pipe wit the thickest insulation you can get.
Keep the timer on 24/7 on the Boilermate. Replace the roomstat with a
Honeywell T6667B1085 CM67 Prog Room Stat With Optimum Start.
http://tinyurl.com/an9q8 Make sure you get the optimum start model - well
worth it. This will then replace the timer on the Boilermate, and give you
far more flexibility than the Boilermate timer, and save on fuel too. Also
easy to get at.
Gledhill advise to keep the DHW on, 24/7.
They are dickheads. I bet they put your boiler in the kitchen or utility
room too. If they had brain they would use a Gledhill Gulfstream 2000 in
the loft, saving space everywhere, and all in one box in the one place.
That is too easy isn't it?
Doctor Evil
Very sensible.
on their website.
Check the installation instructions. I think the frost aspect is built in .
Anyhow have it on 24/7 overcomes any frost problems. You may want to put an
MDF/ply large cupboard around it, and over this have insulation.
Capitol
I hope you both have good service contracts for them! A quick search
seems to indicate a lot of people with nightmare experiences within a
couple of years!
Regards
Capitol
Doctor Evil
couple of years!
Been perfect.
Doctor Evil
couple of years!
Been perfect. I searched and the problems mainly on the Boilermate are
rather silly and minor. One on plumbing pages had a silted up plate heat
exchanger. Gledhills come with strainer. I assume it was left off.
It has a control board and Maxie may tell us if he gets may Gledhill boards
in these days. You can strip out the board and install a blending valve,
flow switch, stem stat and away you go.
Gledhill have a large install base. They are invariably fitted in new homes,
not existing homes. Professionals design the systems on the new homes so
choose appropriate equipment, while jobbbing plumbers would die looking at a
Boilermate as they don't understand them and would not fit one. Gledhill
make units with all the punmps insiode the square casings. Very neat.
Doctor Evil
The Gledhill's do not have flow switches or blending valves, modulating the
DHW pump to maintain the DHW temperature at the taps. If a blending valve
requires replacing it may cost as much as a Gledhill control board. As
Gledhill have few mechanical components, cost of maintenance over the years
will be less than other heat bank systems. Also the control boards do far
more than basic mechanical and electro/mechanical controls, making them
cheaper to run in most cases.
