Most economical wall covering for shop ?
I
Iowa883
I would like to cover up my insulation with some type of board,fiber board
or some type of material .
What would be the most economical right now with steel and wood prices so
high ?
Thanks,
Iowa883
ameijers
high ?
Thanks,
Iowa883
Pff- drywall is awful delicate for a shop wall, IMHO. If you are truly
strapped for cash, check dumpsters and recycle drops for clean wood pallets,
and pull the planks off and drywall-screw or nail them to the studs. Yes, a
lotta labor prying them apart, but usually pretty decent wood, and it allows
you to hang stuff anywhere. Pallets <used> to be penta-treated like ammo
boxes, but I don't <think> they have done that in several years. But just in
case probably a good idea to take precautions when you work the wood. You
can cut the planks to a multiple of your stud spaces and just screw them up
horizontaly like a stable, or get fancy and lay them out herringbone style.
Or more realistically, keep checking the scratch'n'dent aisle at the
big-box, and buy up the dinged panels of that prefinished faux wood stuff
they sell for skinning sheds with. Ugly, but the surface is rather durable,
compared to drywall. Only you can decide- pretty costs. How much ugly can
you live with? If cost was no object, I'd go with 5/4 car siding or
commercial slat wall, myself. (there is a thought- check local store
fittings wholesaler- the ripout material from failed stores usually goes
dirt cheap.)
aem sends...
Curmudgeon
1/4 inch pegboard. Just slap some white paint on it...and you've got a
place to hang every tool you'll ever own.
I
Iowa883
Then I have to seal it correct ?
What do I seal it with ?
Thanks,
Iowa883
L
Leonardo
First post for me....great group.
I rebuilt my 13x22 shop last year. I used 1/4" luan plywood from Menards
for the walls and ceiling... 7 or 8 bucks a sheet at the time. I
finished the seams using some of that 5/16" pine tongue and groove
paneling, that comes in shrink wrap packages, which I ripped into 1 1/2"
strips for battens. It was a cheap and quick solution and I'm pleased
with the look
Lenny
John Gilmer
Drywall may be delicate but it resists FIRE. And, it is very easy to patch
holes and retouch the patches.
You can make a good case for putting up an 1" or so. This will resist
punch through and can still be patch. Two 1/2" layers will do the job.
