Morse taper
cryptogram
I'm intrigued to know how the machine tool taper rules work. I have a drillwhose chuck is a taper fit on the spindle. It appears to me that the spindle is a Morse taper 1 (I may be wrong). If it is indeed this size, I assumed that the chuck (with a female taper hole) would also be a Morse taper 1. But the manufacturers are calling it a B12. In fact, when I told them it was a Morse 1 it threw them until I sent a photo. So my question is, what is the difference between a Morse taper and a B taper (in principle, I mean, not in actual size, because I know there are several different sizes). Surely the male and female would be the same fit, would they not?
shazzbat
This should help -
http://www.jacobschuck.com/pdf/Technical-Information.pdf
According to page 3, a B10 taper corresponds to the small end of a MT1, and
B12 to the large end. So it would appear that the angles are the same.
Steve
cryptogram
in message
This should help -
Steve
Thanks Steve
Drywall outside corners - butt joint or tapered edge 2
tapered dowel 4
Tapering Drywall 7
Tapered plastic shims??? 4
Splined taper 2
tapered concrete pillars 21
Morse kit? 31
Separating Morse Tapers 7
jagga009
