model 6216 Simplicity unable to put into 2 & 3 gear
V
Vern
Goes smoothly into reverse and 1st gear. Only excessive force will put
it into 2 & 3. Any hint what may be happening?
Also, what is the procedure to remove the rear axles? Want to remove
the shroud (which includes the batter platform, etc) that is
captivated by the design of the right side of the shroud around the
axle, i.e. the shroud has a hole on that side. Left side uses a
modified 'U' bolt. Manual shows only a design with modified 'U' bolts
on both sides.
Model 6216Simplicity (Mfg Nr.1690688 - 1671), 1671 is the serial
number. Purchased in 1982.
Thank you, Vern
dpb
Shifter fork worn or perhaps clutch? Don't know anything about specific
model so just the generic manual transmission stuff that would be the
normal suspects would, I think, be the same suspects here.
Also, what is the procedure to remove the rear axles? ...
Probably requires disassembling drive case that would presumably include
integral differential.
No exploded parts diagrams available online? Looking for that would be
where I'd start, but I've no experience w/ Simplicity so don't have a
clue what they have available.
If online fails, what's their service network? Maybe local dealer has
repair manuals would let look at? JD green is good that way; no idea
again about Simplicity.
