Minwax Gell Stain
shoalsman
Seen on Trading Spaces where they used a gel stain on a bedroom set and
explained that there was no sanding or prep work needed! They took a
lighter oak colored set and turned it into a darker wood...
My qyestion is.. is it possible to do the same in reverse? turn a non
real wood surface from darker to lighter? The gel stain is supposed to
go over any paint and surfaces.. to turn a darker surface lighter should
I prime it with kilz first or are there other ways?
Brad
Stain over paint? What kind of look are you going for?
shoalsman
according to the directions on the minwax can there is a tool that you
can buy to drag the stain so that it appears to be wood grain. Just
trying to lighten up the color it is now.
GIJane
I doubt it would work very well going from dark to light. The gel is
somewhat translucent.
A side, don't trust everything you see on Trading Spaces. I can't imagine
the job was done very well unless the surface was already perfect to being
with. TV just isn't close up enough to really "see" anything.
