Maytag dryer
John Smith
Hello:
We have a Maytag MD-15 dryer.
Couple of days ago we were drying some clothes which apparently had some
sand. The sand seems to have gone under the tumbler. So, the next time
when the dryer was operated, an unpleasant noise (as though the tumbler
was rubbing against sand) was heard. I wanted to remove the sand.
I am trying to understand what my options may be: is there any way of
doing it without removing the tumbler? Is it easy to remove the tumbler?
Any advice is welcome.
Thanks.
gfretwell
Hello:
Thanks.
Unplug it and remove the 2 screws from the bottom of the front cover.
It will pull out so you can release the spring clips that hold it on
top. Unplug the door switch. You should be able to blow out the
bearing surfaces from there. If you really want to give it a deep
cleaning, remove the manifold and the drum will be free.
Note and draw a picture of the belt routing if you are pulling out the
drum. I draw it on the deck of the dryer with a sharpie pen. It will
drive you crazy trying to figure it out if you don't.
Did I say UNPLUG IT first? ;-)
Charlie Bress
Drawing a picture is good, but even better is to use a digital camera and
get all the proportions and details right.
Charlie
Thomas Kendrick
Take the dryer outside (it's light). Take off the front lower panel.
Use gravity or a leaf blower (or both) to remove the sand.
Maytag Dryer Problem 0
Maytag dryer repair 3
Maytag Dryer Problem 6
Maytag centenial dryer 5
maytag dryer repair 6
Maytag washer/dryer 6
Maytag Dryer Repair 19
Maytag Dryer DE606 1
