Manual vacuum?
Dale
Usenet Archive
I've got a small pond (800 gallons) that needs to be cleaned out. I won't get into it, but I want to use a garden hose to drain the pond. Isn't there some sort of gizmo that can be attached to a hose to create a pretty healthy vacuum? Where can I get one? Thanks.
Dale
Andy Hill
Usenet Archive
Most waterbed repair kits come with a little gizmo that will create a siphon from running water. Used to be commonly available at K-Mart, Wally World, etc., if you could find someone who knew where they were stocked. You'd want a pretty good screen over than intake to keep 'er from clogging up 'tho.
zxcvbob
Usenet Archive
Dale
It's called a "pump". ;-) Probably a dirty-water pump, although you could use a clear-water pump if you have a good strainer on the suction tube.
I would just use a siphon if possible and let it run for a long time.
Best regards,
Bob
Duane Bozarth
Usenet Archive
Many septic suckers actually just hook up a bypass valve to the manifold vacuum of their truck. Simple, cheap, effective...
Dale
Usenet Archive
I knew it was a pump ;-) but I thought there was a crank-like siphon that could be attached at the end of the hose to get a really good vacuum going. As it is, I'm draining about a gallon a week. Maybe I just need to go and rent a sump pump.
Goedjn
Usenet Archive
Drill-pump. Attaches to your hand drill. At most hardware stores.
YOu'll probably want a bungie cord or clamp the keep the trigger pulled, it will take forever.
Andy Hill
Usenet Archive
If you rent a pump, make sure you rent one that can handle lots of solids (they exist, but ya gotta ask). Most pumps get downright cranky if there is a lot of gunk in the water.
Dan Espen
Usenet Archive
Pool cover pumps can do 800 gallons in 1 or 2 hours.
(The pumps are rated for GPH.)
They're reasonalby cheap and resist clogging.
Duane Bozarth
Usenet Archive
The driving potential is the height differential between the upper and lower ends...the initial pressure drop is immaterial to subsequent flow rate. The problem is a garden hose is such small diameter you're losing it all in friction losses, most likely.
Dan Espen
Usenet Archive
I should have mentioned, they are designed to work with your garden hose.
George E. Cawthon
Usenet Archive
Dale
Yes but you'll run 8000 gallons (minimum) to drain
the 800 gallons out and only if you have a very
load elevation change. Even one of those little
pump gizmos (about $10) to put on a drill would
more much better. (Forget this idea.)
What you need is a pump, a real pump, maybe a
sump pump would be the way to go.
George E. Cawthon
Usenet Archive
Best regards,
Bob
What makes you think his pond is at a higher
elevation that where he wants the water to go?
Bennett Price
Usenet Archive
For a siphon to work, the discharge end of the hose must be lower than the intake end. If you can arrange that, just fill a hose with water, keep the discharge end sealed until you dunk the intake side into the pond, then open up the discharge end. (A hose sprayer can do the sealing for you.)
cowboy
Usenet Archive
Walter is correct
SIPHON IT
REAL men siphon, yuppie metrosexuals use pumps!
PaPaPeng
Usenet Archive
WalMart has a bilge - live bait tank (12 volt DC) pump for $20. Garden hose size. Works great.
Toller
Usenet Archive
cowboy said:
Walter is correct
SIPHON IT
How do you siphon a pond? It is almost certain to be the lowest point around.
Goedjn
Usenet Archive
Depends on the pond. If it's one of those
plastic lines ornamental ponds, a "real" pump
may pull enough water to damage it.
lisac
