Mains screwdriver
meow2222
Usenet Archive
Been offered one at a very attractive price, but cant decide. Are they still worth having these cordless days? This one isnt an autofeeder.
NT
polygonum
Usenet Archive
NT
For lightweight screwdriving, there are plenty of usable, cordless machines.
For heavyweight screwdriving, there are impact drivers. And even a relatively small and lightweight cordless one can have fantastic driving capability.
So where does a mains screwdriver come in? Unless battery life is very important.
meow2222
Usenet Archive
Quite. Decent cordless kit has largely displaced them. The only plus afaik now is when doing loads of screws, and even then recharging doesnt take too long. I loved such kit once.
NT
Tim Watts
Usenet Archive
Agree..
My 4 year old Bosch GSR driver can cope with 5mm 100mm screws. For my rare needs to driver bigger things, I put a hex bit in my mains drill :)
Thomas Prufer
Usenet Archive
I worked with a Fein mains one. Had a clutch that engaged when it was pressed down, which meant one could keep the motor spinning, and just screw in one after another. Absolutely great for screwing down squeaky floorboards, where I used many hundreds of long thick screws, 5x60 or 5x80. Fire it up, run in a box of screws, stop the motor.
(A tip someone gave me was to tape up the screw-holding fingers beforehand -- gaffa, masking, sticking plaster, anything -- as the screw threads would chew up the skin after a while.)
Very good for continuous work, or battery-draining stuff like long thick screws, or work where it matters that it is a little bit faster. Otherwise, rechargeables with a second battery pack and a quick charger are probably more versatile.
For a "very attractive price", *I* would get one.
Thomas Prufer
meow2222
Usenet Archive
I worked with a Fein mains one. Had a clutch that engaged when it was pressed down, which meant one could keep the motor spinning, and just screw in one after another. Absolutely great for screwing down squeaky floorboards, where I used many hundreds of long thick screws, 5x60 or 5x80. Fire it up, run in a box of screws, stop the motor. (A tip someone gave me was to tape up the screw-holding fingers beforehand -- gaffa, masking, sticking plaster, anything -- as the screw threads would chew up the skin after a while.) Very good for continuous work, or battery-draining stuff like long thick screws, or work where it matters that it is a little bit faster. Otherwise, rechargeables with a second battery pack and a quick charger are probablymore versatile. For a "very attractive price", *I* would get one.
Thomas Prufer
I reckon I could get him down to £8, but as folk say I dont think its worth it. For sheds I've got other kit that will do the job. I dont do decking.. Thanks everyone
NT
The Medway Handyman
Usenet Archive
I have a mains impact driver to back up the cordless one when decking, it extends the batteries life, means we have two on the go & cost less than the price of a Ni/Mh 3 amp battery.
polygonum
Usenet Archive
I can certainly see it if you are regularly doing things likes decks.
lisac
