Dave H.
Knowing what practical sorts are likely to visit this group, I'd like
recommendations for paint for my new project, a Holbrook Model C lathe -
originally it was a shade of Institutional Green, which I may choose not to
repeat on grounds of taste (or lack thereof)...
At present my plan is to strip the original paint back to bare metal
(apparently Mr Muscle oven cleaner is a good choice for this, with less
health risks than Nitromors etc.) and clean with thinners, apply a coat of
bare-metal primer, fill any obvious pits (Isopon or similar) and sand,
before applying further primer and the top (colour) coats with further
sanding in between.
I've heard scary stories about 2-pack (e.g. epoxy and other) paints and
hazardous chemicals, although I'd be brushing rather than spraying if I were
to go for such, on the assuption that it's the vapourisation of the
catalysts etc. that leads to problems - Ideally I'd avoid them if there's
something else that's suitable.
I've seen a few favourable comments on "Combi Color" enamels and associated
primers, some quite negative ones on Smoothrite etc. and not many on
Tekaloid (most of the sites that discuss machine painting seem to be
transpondian, with different brand names!), has anyone any opinions on which
would be most suitable? The poor thing's likely to have spanners and
chuck-keys etc. dropped on it from time to time, coolant (probably neat
cutting oil rather than soluble) and smoking swarf all over it, so
durability's a major factor (I'd quite like it to look good too, though!)
Any rebuilders or restorers of old iron have any suggestions?
Thanks,
Dave H.
sanding in between.
Thanks,
Dave H.
