Location of Earth Spikes
W
Wolfy
I have to move my earth spike which is currently outside behind the garage
about 15 yards from the fuse box. Does it have to be outside, or can it be
moved inside and closer to the fuse box
TIA
Wolfy
ARWadsworth
Wolfy said:
My garage floor is concrete and is built on rock (a quarry). I was going to
drill a 9mm hole about 18" dep and hammer the spike into the hole. all this
could be done very close to the distribution boxes. Does that sound OK and
safe ? Also there are no warranties in force as the house is over 40 years
old.
I do no see why not, except I do not think you will be able to drive an
earth rod into rock and the final impedance should be measured with special
equipment to show it works safely.
Adam
BigWallop
ARWadsworth said:
can knocking going
Adam
I would concur with that.
Jb
To improve (lower) the resistance drill slightly oversize, fill with rock
salt and drive the spike into that. Checking the earth resistance really
should be done, esp in your circumstances.
Jb
