Lidl battery charger repair
Mark
You may remember that in another post i commented that i had a FOC
replacement for the failed Ultimate speed charger.
Dismantled the old one today and the cause of the failure was the cheap
DPST/PTM switch, pity such nice electronics let down by a 10p switch.
Works fine now, and i have two for the price of one :)
http://img844.imageshack.us/img844/1167/dscf0941cy.jpg
Grimly Curmudgeon
Nice one. Always good to have more than one.
Dave Plowman (News)
replacement for the failed Ultimate speed charger. Dismantled the old
one today and the cause of the failure was the cheap DPST/PTM switch,
pity such nice electronics let down by a 10p switch. Works fine now, and
Nice one. Do you have a part number etc for the switch replacement - there
seem to be thousands of variations.
Mark
It’s a 6x6mm Momentary SPST (not DP as i originally said) like this
http://www.ebay.co.uk/itm/180732232689 first hit on ebay you may find
better.
i have binned the original but the button length is about 4mm
i salvaged mine from a dead freeview box, it may be easer to get one with a
6mm button and cut a bit off then trying to add a few mm like i had to.
With mine the fault was with it connected to a battery and powered up the
red standby light lit but pressing the menu button had no effect YFMV.
brubbel
Replacing the miniature push button with a spare one from a toaster fixed the problem. I was also suspecting the button at first but I thought it would be too straightforward.
Thanks!
