laminate flooring
Kee
Usenet Archive
is it better to remove the baseboard and reinstall it after flooring is done? or leave the baseboard there and install quater rounds after flooring is done?
also what kind of transition moulding would you use at a glass sliding door panel?
Edwin Pawlowski
Usenet Archive
I removed the baseboard and I think it does a better job and has better appearance as the baseboard would look squished otherwise. Mark the bb so it can easily go back in the same place after you paint or varnish it.
I used a pre-finished molding that the company could provide. I used www.mannington.com engineered wood in my family room and hall. Years ago, I used www.wilsonart.com for the stairs. Both are good products.
Kee
Usenet Archive
thanks, edwin
lisac
