L.E.D lighting for kitchen anyone?
JethroUK©
I've decided to scrap some 12 volt x 50 watt halogen spot lighting I have in
my kitchen
In particular a 6 light cluster (x 50 watts =300 watts) because it's too
expensive, i'm not sure it's even safe and it's still not that bright
You cant seem to buy flo-tubes any more and they're not very attractive
It seems that LED seems to be the only option - they very, very low
consumption making them cheaper and safer to run - but are they bright?
Any pointers/links
If they prove to be successful i will also replace 2 x 4 cluster spots as
well
JethroUK©
P.S. I'm assuming i can't just replace GU10 12v halogens with GU10 LED's
Clive
in my kitchen
Why wouldn't it be safe. Did you fit them yourself?
You're lazy as B&Q and many other retailers sell fluorescent tubes.
They are prefectly usable and provide far more light than small halogens and
dim LEDs with limited coverage.
No, they are crap for lighting a room.
Any pointers/links
The Internet would be a start, maybe a few shops that display hundreds
of LED light fittings.
well
Next you will be asking how to replace them or for a number of someone
that will do it for you.
ARWadsworth
Ash said:
You know I'm not sure ... they certainly only take a small amount of juice
to light up but whether they'll work with a 12v system I don't know.
Hopefully someone else will know the answer for you.
Ash.
I have not seen a GU10 12v lamp.
GU10s are 230v rated. It matters not if they are GU10 LED or GU10 230V
lamps. GU10 lamps are rated to use 230V. This makes sure a 12V lamp is not
shoved into a 230V light fitting. They have different fittings to the 12
volt MR16 fittings.
You can buy 12V LED MR16 lamps
I can assure you that the GU 10 LEDs are a waste of space.
Adam
JethroUK©
volt MR16 fittings.
You're quite right - After taking another look, my lights are actually
240v - not sure why I had it in my head they were 12 v - it just was :eek:)
Does that mean 12V LED MR16 lamps are better, or are you saying LED's per se
are poor?
Andrew Gabriel
are poor?
LED products you find aimed at the retail market are very poor,
particularly MR16 and GU10 retrofits, as those bulb formats are
unsuitable for LED lighting at enywhere near equivalent levels
of filament lighting. To a first approximation, assume that 1W
of LED will be equivalent to 1W of filament lamp for these cheap
crap consumer products.
There are commercial LED products available which are viable,
but they are at commercial prices, and well outside retail
price ranges. You'd need a fairly good knowledge of lighting
design to use them, or to employ the services of a lighting
designer.
The other option is to design and make your own, which I've
done in one case using the professional quality LED components,
which can be bought for reasonable prices. You'll then need
to design the optics, heat management, rest of the fitting,
and the power supply.
jenny
Edlite Company Limited
Attn:Jenny TEL:+86 20 84352833/84333703 FAX:+86 20
84348881 http://www.edlite.hk
LED Series
1. ED-F8 LED series flip-open slim light box(with alluminum frame
20mm width,15mm thickness)
Spec. Model " Frame Size
(mm) " Visual size (mm) Film Size (mm) Light soure Power Unit
price (USD) Units per Carton(pcs)
ED-F8-A1 624x871x15 584x831 594x841 LED 20W 120 5
ED-F8-A2 450x624x15 410x584 420x594 LED 14W 82 10
ED-F8-A3 327x450x15 287x410 297x420 LED 8W 50 10
ED-F8-A4 240x327x15 200x287 210x297 LED 6W 36 20
ED-F8 single side LED flip-open slim light box
2. ED-F11 Long life-span flip-open slim light box(with alluminum
frame 25mm width,25mm thickness)
ED-F11-2A 1221x1894x25 1171x1844 1189x1862 LED 40W 550 2
ED-F11-B0 1032x1446x25 982x1396 1000x1414 LED 30W 400 2
ED-F11-A0 873x1221x25 823x1171 841x1189 LED 25W 310 2
ED-F11-B1 739x1032x25 689x982 707x1000 LED 20W 190 2
3. ED-F10 LED series flip-open slim light box
(with alluminum frame 25mm width,30~40mm thickness)
ED-F10-A1 626x873x30 576x823 594x841 LED 40W 219 5
ED-F10-A2 452x626x30 402x576 420x594 LED 28W 144 10
ED-F10-A3 329x452x30 279x402 297x420 LED 16W 85 10
ED-F10-A4 242x329x30 192x279 210x297 LED 12W 57 20
ED-F10 Double sides LED flip-open slim light box
4. ED-DP Double Sided Crystal Frame Slim Light Box (only 15mm in
thickness)
(mm) " "Visual Size
(mm)" Film Size (mm) Type of tube (mm) Power Unit price (USD)
ED-DP-A1 600×900×15 450×750 470×770 LED 16W 165 4
ED-DP-A2 460×600×15 335×475 360×500 LED 14W 100 10
ED-DP-A3 300×385×15 200×285 220×305 LED 8W 49 10
ED-DP-A4 260×310×15 195×245 205×255 LED 6W 40 10
ED-DP double sides LED crystal slim light box
5. ED-P Single Sided Crystal Frame Slim Light Box (11mm in
thickness)
(mm) " "Visual Size
ED-P-A1 600×900×11 450×750 470×770 LED 16W 123 4
ED-P-A2 460×600×11 335×475 360×500 LED 8W 75 10
ED-P-A3 300×385×11 200×285 220×305 LED 5W 45 10
ED-P-A4 260×310×11 195×245 205×255 LED 4W 32 10
ED-P Single sides LED crystal slim light box ED-M3
6. ED-M3 LED Magnetic Strip Front-open Aluminum Frame Slim Light Box
(frame width 20mm ,17mm thickness)
ED-M3-A1 624x871x17 584x831 594x841 LED 20W 140 5
ED-M3-A2 450x624x17 410x584 420x594 LED 14W 90 10
ED-M3-A3 327x450x17 287x410 297x420 LED 8W 65 10
Remark: Custom-made size is welcome
The quoted price is based on EX-factory terms ,
discount is according to the quantity.
The quotation is not including the film
price.
Edlite LED Lamp strip
Edlite newly invents the LED lamp strip for the slim light box.Our
exclusive backlit LED lamp design is specially for the indoor or
outdoor light boxes by using with or without the light panel.It can
also have the slim outlook but with quality luminous and durable
usage.It use the specially SMT backlight LED.It has the special design
in power control and cooling system for keeping the LAMP long
life.
LED Lamp Strip
Lamp space Fixed width Length DC Lumen PCB Constant source Cooling
system Apply
① 10mm 11/13mm 300mm 24V 108 Alu. √ Edge lit
② 5mm 13mm 300mm 24V 216 Alu. √ Edge lit
â‘£ 10mm 5mm 300mm 12V 90 Epoxy Edge lit
⑤ 70mm 60mm 370mm 24V 520 Alu. √ √ Edge lit
â‘¥ 6mm 6mm 500mm 12V 250 Epoxy Edge lit
⑦ 10mm 8mm 390mm 12V 117 Epoxy Edge lit
â‘§ 6mm 7mm 500mm 12V 350 Epoxy RGB
⑨ 10mm 8mm 500mm 12V 190 Flex Edge lit
⑩ 12mm 8mm 250mm 12V 40 Alu. √ Back Lit
Chewbacca
Snip
yes my mate changed his mixture of 6 off 12V 50W MR16 and 8 off 240V 50W
GU10 lights in his kitchen to LED's. (12V fitted in kitchen extension,
230V in original kitchen...very strange).
Snip
I am so glad he has put the halogens back as when I go round for a meal
I can now see what I am eating......
6 off 50W & 8 off 50W gives a total of 700W of halogen light.
I am surprised you can see anything in that much light.......
cpvh
Sorry to be late to the party as usual. I am considering six ZEP1s from Ecoled for my ten by twelve kitchen. Has anyone any experience of these or care to comment on the specs?
jagga009
