Jacking wood rafters
W
Wayne Whitney
Hello,
I have a 1910 home in which the roof is grossly underframed, and I
would like to strengthen it so I can install solar panels. The
original 2x4 rafters at 32" o.c. span 12' 3" in plan from plate to
ridge and support the original 1x skip sheathing, 1/2" plywood, tar
paper, and one layer of architectural asphalt shingles. I checked a
couple of the rafters with a string line, and they are deflected about
1 3/8" at midspan.
My plan is to strengthen the roof framing by adding rafters to modern
framing standards. AWC's on-line span calculator indicates that
DF-North #1 2x6s rafters at 16" o.c. will handle the span with 10 psf
dead load and 20 psf live load. Since I don't see any way to attach
the new rafters to the sheathing without disturbing the asphalt
shingles, I am planning to install doubled 2x6 rafters alongside each
of the original 2x4 rafters and sistering them together.
Is there a better way to go about strengthening the roof framing?
To install the new rafters, I will have to remove the deflection of
the existing rafters so the new ones will fit and properly carry the
roof load. I can jack against the ceiling joists over a bearing wall
below. I am tempted to install the new rafters with the crown down to
reduce the jacking required. The roof is hipped, so the ridge is only
16' long and there are only 7 common rafters on each side of the roof.
I'm going to leave the rest of the rafters as is.
What are my chances of getting the existing rafters to move 1 1/2" or
so without damaging the plywood sheathing or ashphalt shingles?
Can I get away with jacking the rafters one at a time, or should I
arrange to jack all seven rafters on a side at once?
In case it is important, the rafters don't bear directly on the
exterior wall plate; instead, there is a flat 1x plate installed on
top of the ceiling joists (2x6s at 16" o.c.), and the rafters bear on
that. I'm planning to install the new rafters on the same 1x plate,
add squash blocks beneath them, and figure out a strap detail to tie
the new rafters to the wall plate.
Thanks, Wayne
jloomis
Anyway to put a strongback or beam at midspan of existing rafters?
Even like an overhead beam ontop of or above ceiling joist supported at
either end.
Then support rafters on that?
It sounds like doubling is a good way to go.
I would try to raise rafters in a group if possible.
john
"Wayne Whitney" wrote in message
Hello,
1 3/8" at midspan.
Thanks, Wayne
W
Wayne Whitney
at either end. Then support rafters on that?
Thanks for your response.
The problem with supporting the rafters at midspan is there's no
foundation underneath that area. So I'd have to transfer the point
loads to doubled or tripled 2x6 ceiling joists or 2x10 floor joists to
carry the load to the perimeter foundation and the central girder.
And so it seems better just to triple the rafters directly.
It sounds like doubling is a good way to go. I would try to raise
rafters in a group if possible. john
I had been thinking of using a screw jack to raise the rafters one at
a time. I could get several screw jacks to lift a temporary beam
under all 7 rafters.
Or I could try raising each rafter with a 2x4 running diagonally from
rafter midspan to the house centerline, cut to the proper length so
the rafter will be straight once the 2x4 is in place. Then I can
install the 2x4s with a sledgehammer, doing all seven roughly in
parallel. Anybody done that before, will it work?
Thanks,
Wayne
DD_BobK
Thanks,
Wayne
Wayne-
parallel. Anybody done that before, will it work? <<<<<<
Sounds like you're approaching a site built truss arrangement.
I have 4ea jack posts & screws that you can borrow.
My house (1930) has 2x4 "rafters" but they're braced at midspan back
to the house centerline creating a site built truss.
Do oyu have space in the attic to add the members and do the work?
cheers
Bob
W
Wayne Whitney
Hi Bob, it's been a while. How've you been?
I'm not going to go the truss route for a couple reasons. First the
chords would be obstructions for using the attic, although that is not
a large concern as I don't use it much. More importantly, the rafters
are not in plane with the ceiling joists! The ceiling joists are
consistently 16" o.c., but the rafters vary from 30" - 37" o.c. and
average around 34" o.c.
So really the issue is just the best way to straighten the existing
rafters so I can fit the sisters in place. I'm first going to try
pounding some temporary chords into place; if that doesn't work I'll
try screw jacks.
Cheers, Wayne
W
Wayne Whitney
from rafter midspan to the house centerline, cut to the proper
length so the rafter will be straight once the 2x4 is in place.
Then I can install the 2x4s with a sledgehammer, doing all seven
roughly in parallel. Anybody done that before, will it work?
Update: the temporary chord method worked well, although I ended up
needing two per 16' 2x4 rafter to get them straight. With the rafters
32" o.c., the roof deck was flexible enough that I could straighten
the rafters one by one.
Cheers, Wayne
phildcrow
Cheers, Wayne
Wayne,
Having just put a new metal roof on my house (1928), I would keep a close eye out during the next rainstorm to make sure you don't have any leaks generated by moving all that asphalt on the roof around. Between the time I closed in the existing shingles with the R-panel, I had a new leak develop just from us mucking with the existing framing.
Good luck, and it feels really good to fix your own stuff, doesn't it?
Phil
