Ivy remains
W
Wayne Joyce
I've just been removing the ivy that has been growing up the wall of my
house and wondered if there's anything I can use to remove the fine "roots"
of ivy from the brickwork. I've tried a wire brush, but it isn't shifting.
Any clever tips?
Cheers,
Bod.
Martin
Any clever tips?
Cheers,
Bod.
Had the same problem - until this afternoon - having tried brushing,
pressure washer etc.
Depends on the kind of brick you've got, how "clean" you want to get it, and
how determined the suckers are, but I ended up using a flat-edged sharp
spade sideways - like a massive scraper. Worked a treat for us - with no
visible damage to brick facing.
HTH
BillR
it, and how determined the suckers are, but I ended up using a
flat-edged sharp spade sideways - like a massive scraper. Worked a
treat for us - with no visible damage to brick facing.
HTH
I've got the same problem and this won't work for me as the bricks have a
grit surface effect.
Did try burning the crud off with a blowlamp but nearly set fire to the
battens & felt under a tile hung bit :)
I'm going to leave it a year or so and try again when its well and truly
rotted away..
Poison Ivy 26
Help with Poison Ivy 7
Ivy 13
Ivy 18
shredding Ivy 8
Ivy on wall 2
Remains of Lamp Post 34
Poison Ivy Removal? 9
