Isolating valve for flexible tap tails
John
I have bought a tap with 2 flexible tails (rubber washer for the seating in
the connection).
I want to fit isolation valves - the ones I have seen have compression
fittings at each end. I presume I want something a bit different to attach
the flexible. Any pointers?
The Medway Handyman
seating in the connection).
attach the flexible. Any pointers?
Do the flexibles screw into the tap at one end and have a female with a
rubber washer at the other.
Like the connector on the left end here
http://www.toolstation.com/shop/Plu...r+300mm+15mm+x+12+10mm+Bore/d20/sd2807/p29829
If so the female will fit straight onto the isolating valve & seal.
If your flexibles end in compression fittings then a short piece of copper
tube will sort it.
Jim K
Like the connector on the left end herehttp://www.toolstation.com/shop/Plumbing/Flexible+Connectors/Flexible...
tube will sort it.
mmm
I asked a similar one not so long ago on here - Tim W had this
"I don't think that would be a good idea. The rubber washer in teh
flexi
expects a flat shoulder on the mating fitting. The shoulder on a
compression
joint tends to be sharper and not designed for washers.
I had the same dilemma when swapped a ballcock from a stupid plastic
threaded bit of crap to a proper one with a solid brass thread.
The plastic one was designed for a tap connector (not much else they
could
do) and the brass one for a compression joint to pipe and it had a
very
sharp shoulder. Don't think a rubber washer would have lasted very
long..."
Jim K
dom
mmm
flexi
compression
could
very
long..."
Jim K
In which case use washing machine taps:
http://www.screwfix.com/prods/51231...m-x-Washing-Machine-Valve-without-Check-Valve
John
tube will sort it.
Yes - female threaded nut - washer inside. I guess like a tap fitting.
John
Jim K said:
erm... the 3/4" bit might cause a slight (1/4") prob? ;>)
Jim K
My concern (perhaps I had subliminally seen it earlier):
"I don't think that would be a good idea. The rubber washer in the flexi
compression joint tends to be sharper and not designed for washers.)
andrew
Flexi onto isolating valve has always worked fine for me. If necessary
look at a couple of brands of compression isolating valves. The ones
I've used do have a smaller surface to contact with the rubber washer,
but they are certainly not sharp, and unless you really went for it
with a wrench, wouldn't cut through the rubber.
N
newshound
in the connection).
You can also get pushfit ones. These days I tend to use the ones with a
proper "lever" rather than the screw head: I find these easier to operate.
The "butterfly" type, e.g. BES part 11775 or Screwfix 21860 are fairly
compact. You might also look at BES "mini ball valves" which are threaded
each end.
The Medway Handyman
Exactly my experience. Never had a problem.
