Lots of good posts in this newsgroup but could not find the answer. Here is my question:
Considering our Seattle climate, where the temp outside the house is below 70F for some 5 months of the year and above 70F during the other 7 months and humidity is fairly moderate, what would you recommend for the optimum insulation material and how would you deal with the vapor movement (one local insulation contractor suggests no vapor barrier within the wall but rather on inside of the sheetrock; he also suggests staying away from spray-foam saying that air movement is very much needed)?
I am definitely considering installing a Heat Recovery System to ventilate the house as much as needed. Other than that I am for installing a system which works well and has value (good bang for the buck). I don't mind spending extra if I can recover the cost (by lowering energy bills) in 5 years or so. Fiber bats and spray foam are my choices (as I don't like the duct-effect of blown-in very much).
This new 2-store house will be on crawlspace, will have 2X6 exterior walls (per local code) and a combination of attic and cathedral ceilings. I will have radiant heating floors on both floors and AC installed only on the second floor via attic (lots of open spaces for the cold air to drop down).
Any suggestions would be appreciated.
Thanks much.
Thanks much.
