David (archive)
Usenet Archive
- Joined
- Jan 11, 2000
- Messages
- 1,563
- Reaction score
- 0
Hi
Have just bought a new multifuel stove on ebay and essentially it seems fine but definitely no frills at all - even down to no assembly / installation instructions.
Proposing to use existing open coal fire flue [had it swept] blocking off with masterboard and just poking a rear 5 inch horizontal flue pipe through a sealed hole in the board.
Will I need any form of flue bend back of the board, within the old hearth area after that ? - a bit confused 'cos intuitively one wants to deflect it all upwards but I've seen other strong recommendations to avoid bends in these flues and suppose all will rise anyway if the flue is working OK Believe current building regs. really require a T piece with one end capped but these alone seem to be £100++ and budget is tight so would rather avoid.
Will I really need to put a mound of rubble into bottom of hearth and cap it off with sloping mortar, as I've seen advised or can I just leave it empty ?
Re future access to the flue for sweeping, it seems that would be possible through the rear flue outlet but that's not a full 5 inch diameter 'cos of the spigot bolting lugs cast into it - is this still ok or should I make some little door in the masterboard and seal/ screw them ?
Finally, the top flue outlet seems to come ready-fitted with a blanking plate that obviously one transfers to the rear flue if using the former - should I leave well alone or is it better to take it off and put it back with aid of some fireproof sealant ?
Any constructive guidance would be very gratefully received !
David
David
