Insane House Cool-Down Scheme
Puddin' Man
Usenet Archive
Re: Insane House Cool-Down Scheme
'allo,
I belong to little brick bungalow in a midwest city,
built in 1954. Shingled roof.
It gets hot as hell here in the summertime (it's already here). Sun pounds down on little house unmercifully.
Outa work for years, I gotta budget so tight it makes
the proverbial cat's arse ('scuse my French) look
like the Grand Canyon.
I just put my last 3 lbs of R-22 in my 21-year-old
condensing unit (which is about to roll over and die
a horrible, horrible death).
They don't meter the water supply here.
What (aside from sanity, which I do not possess) would
keep po' me from somehow mounting a sprinkler or 2
on the roof, running them with a garden hose, say,
from 11 AM to 7 PM (to cool the house, which retains
heat like crazy)??
TIA,
Puddin'
*** Puddin' Man PuddingDotMan at GmailDotCom ***
Stormin Mormon
Usenet Archive
A lot depends on the humidity in your area. If it's dry, the roof wet will help a lot.
Might also want to consider a sprayer to spray cold water on the outdoor AC (get your AC guy in on the plans). If there is little evaporation, that might lower the temp of the outdoor unit, and help system that way.
White curtains in the south and side windows to help block out the "greenhouse effect". White exterior paint. Well, maybe not for brick but....
Wish I was closer, I'd offer to come out and look at the system for you.
Christopher A. Young
Learn more about Jesus
www.lds.org
www.mormons.com
'allo,
heat like crazy)??
TIA,
Puddin'
Mike Dobony
Usenet Archive
'allo,
heat like crazy)??
Lack of a hose or sprinkler? Can you shade the condenser? How about a fine mist on the condenser to remove more heat from the condenser? Do you have a basement? One tirck I use is to put the fan in the "ON" position and I also have cold air returns in the basement. This helps bring the cool basement air upstairs. If you're outa work, how about spending the day at Walmart?
Raid
Usenet Archive
Well you might try getting off your ass and get a job!
you say you have no money but you have a computer and a ISP. need to save some money then turn off the A\C ......
It will work just fine, spray the roof till they come and install a meter! With fine thinking like that, Bush is gonna come knockin at your door when Greenspan retires but you'll be watchin stolen cable tv or too drunk to answer the door and accept the appointment. I love the comment about spending the day at wallmart but he prob already does, as an employee get paid next to nothing in sinking american dollars. This guys represents all that is great about americans! Lazy, broke, cunning. Anyone want to ad to the list?
Hound Dog
Usenet Archive
How about too generous at allowing foreigners into our country to share our horrible life.
Guest
Richard J Kinch said:
That scheme is unlikely to be efficient, with lots of thermal resistance (insulation) between the living space and the roof, and it's the wrong time of day to collect coolth, but Harry Thomason did something like this in the 60's for hundreds of houses, including his own in Washington, DC (a bad climate for evaporative cooling) pumping water over the roof at night and storing and distributing coolth during the day. He also ran an AC at night, when ACing is more efficient.
In "Solar Space Heating and Air Conditioning in the Thomason Home" (Solar Energy Journal, Vol 4, No. 4, Oct. 1960, pp 11-19), Dr. Thomason wrote "...the water on the north sloping roof flows slowly in an almost perfect thin sheet from top to bottom. The granules of sand in the asphalt shingles help to spread the water evenly and to retard the rate of flow... On the night of 14 July the rate of cooling was 25,700 Btu/h at the peak when the sky was overcast, but there was a breeze of about 15 mph. Outside air was at 68 F, water to the roof was at 73 F, with a return temp of 65.5 F and a flow rate of 5 gallons in 41 seconds. Humidity was about 65%."
Thomason used a 1600 gallon steel tank surrounded by rocks for heat and coolth storage and distribution. A homeowner with a basement might cool a house by pumping water over a roof at night and collecting it in a gutter and letting it flow back into some 4" thinwall PVC pipes or poly film water ducts tucked up between basement ceiling joists and circulate air between the house and the basement during the day.
NREL says an average 75.6 day July day in Sterling, VA (close to DC) with an average daily 64.1 and 87.0 min and max has a humidity ratio w = 0.0136 pounds of water per pound of dry air and an average V = 6.2 mph windspeed.
With average night temp Ndbt = (75.6+64.1)/2 = 69.9 F and vapor pressure Pa = 29.921/(1+.62198/w) = 0.640 "Hg and dew point Tdp = 9621/(17.863-ln(Pa))-460 = 65.5 F, the approximate wet bulb temp Twb = (Ndbt+Tdp)/2 = 67.7 F. With lots of T = 70 F water flow, Phil Niles says A = 0.002056*Tdp+0.7378 = 0.8725 for a radiation loss Qr = 1.63E-09*((T+460)^4-A*(Ndbt+460)^4) = 16.5 Btu/h-ft^2 plus convection loss Qc = (0.74+0.3*V)*(T-Ndbt) = 0.3 Btu/h-ft^2, with B = 3.01*(0.74+0.3*V)*((T+Twb)/65-1) = 8.753 and evaporation loss Qe = B*(T-Twb)-Qc = 19.8 Btu/h-ft^2, for a total Q = Qr + Qc + Qe = 36.6 Btu/h-ft^2, or 12Q = 440 Btu/ft^2 per night.
A small 1000 ft^2x8' house with 200 Btu/h-F of thermal conductance and
0.5 air changes per hour with 600 kWh/mo of indoor electrical use that's 80 F with w = 0.012 indoors would need about 70K Btu/day of cooling, which might come from 70K/440 = 160 ft^2 of roof.
It would need about 7100 Btu/h of peak cooling. If that comes from 1000 ft^2 (about $150) of ducts in the basement ceiling, the min duct water temp would be about 80-7100/(1000x2x1.5) = 77.6 F. If the house needs 350K Btu for a warm humid week, with no significant cooling at night, 350K = (77.6-70)C makes C = 45,851 Btu/F, eg 23 tons of water in 8.8" deep ducts (a good ballast foundation :) More roof or basement ceiling surface would reduce the water depth.
As an alternative, we could cool static basement ducts without plumbing or pumping with a whole house fan on cool nights. Dr. Thomason also used a small dehumidifier.
Nick
JRanieri
Usenet Archive
'allo,
heat like crazy)??
Couple thoughts: Why bother cooling off the whole house when the only thing that really needs cooling is _you_? With that in mind, leave the cold water running in the shower and stay in there during the hottest part of the day.
Or - a looping configuration of copper pipes encircling the La-Z-Boy with constant cool water circulation?
Just brainstorming here.
Puddin' Man
Usenet Archive
A lot depends on the humidity in your area. If it's dry, the roof wet will help a lot. Might also want to consider a sprayer to spray cold water on the outdoor AC (get your AC guy in on the plans). If there is little evaporation, that might lower the temp of the outdoor unit, and help system that way.
The house fries mostly 'cause of the sun on the dark-brown shingles.
Thanks, but there's not much to it. Just a little brick bungalow in the sun.
Puddin'
'allo,
heat like crazy)??
TIA,
Puddin'
Puddin' Man
Usenet Archive
Why not just fix the leak in the A/C.?
1.) It's a Carrier, circa 1984, with long lines
from the A-coil. I tried for years: it don't
fix.
2.) Can't afford the elec. bill. I can run it
a tiny bit, but now way all day/evening.
Puddin'
Matt (archive)
Usenet Archive
Why not combine these two ideas? Strap the wookie
(http://www.passedoutwookies.com/) down in his la z boy, and connect one copper tube to his neck, another one at his foot. Route the one coming out his foot to a floor drain, and the one going in his neck to the water supply; turn water on.
Puddin' Man
Usenet Archive
More like I haven't figgered how to mount sprinklers/hose on the roof.
Wouldn't hep' that much. Can't afford to run the AC much ...
Do you have a
basement?
Si, senor.
Interesting. I don't have any returns in the bsmt, but I 'spose I could cut some.
Tell the truth: are those folks human?? :)
Seriously, I'm pushing 60 and have some physical problems. Can no way stay on my feet all day.
Puddin'
Andy Hill
Usenet Archive
'allo,
heat like crazy)??
I've seen horse stables here (Idaho) cooled with a similar system. Works OK, although our humidity is a lot lower than the Chicago area.
My *guess* would be that you might cause the roof to fail prematurely -- asphalt paths that are watered (sprinkler) on a daily basis wear out a lot faster than paths that are kept dry most of the time. Of course, keeping the roof cooler may more than make up for keeping it wet all the time.
oconnell
Usenet Archive
Puddin' Man said:
Re: Insane House Cool-Down Scheme [snip]
heat like crazy)??
Nothing, but don't expect much.
It's a strong function of the temperature of your
water coming out of the hose, which is probably a
bit under 70F if your lucky. But it will take ALOT
of water, and flowing pretty quickly. It will
also tend to cool the peak of the roof the most.
It's also hard as heck on the shingles. Do you
have any roof ventilation? That's gonna help
the most.
Planting grass up there would probably do more,
but the roof probably can't take the weight.
JRanieri
Usenet Archive
Matt said:
day.
Actually, just coiling the copper pipe around Puddin's neck - much like the rings worn by certain African tribeswomen- would probably keep him cool. Fitting the copper to a lengthy flexible hose would also allow him the mobility to leave his La-Z-Boy to make sandwiches and such.
Drainage may be problematic, though.
Guest
I believe that, rather than collecting coolth, he is trying to reduce the infiltration of heat during the day.
That seems more easily done with a light-colored roof, attic ventilation, and a radiant barrier or insulation in the ceiling below.
He is not trying to collect the runoff water, which has been heated, not cooled.
It could be cooled and collected at night...
Then again, PE Drew Gillette (deanegathotmail.com) replies:
Good idea-- would work primarily to reduce heat gain from roof (which also could be countered with white paint or better or radiant insulation) as opposed to cooling the house directly as the thomason system below does.
Only enough water is needed to just keep the roof moist in daytime and let evaproration do the cooling job. nick can figure how much this is. I don't believe it would be much at 1000 btu per pound. (70 pounds, 10 gallons per day to meet house heat gain load below.) Or 300btu/sq.ft/hour solar gain /1000 or 1/3 pound per hour per square foot to keep up with maximum solar heat gain on roof. Thats only 40 gph for a 1000 sq.ft roof. It's only a trickle, that's why they call it a trickle colllector.
If more water is used, it could be collected and used as preheated water for domestic hot water storage tank. given that we need both cooling and heating, it seems we should collect and store both rather than just throwing out.
PE Joe McCabe in Ca did some work on using this misting approach to keep his roof mounted pv clean and cool enhancing its performance. he has reported on it at ASES confs.
I'm doing some work with www.dawnsolar.com using plastic pipes under metal roofing under PV to pull heat off roof(and pv) and store it for dhw, but it doesn't take advantage of the evaporative effect.
The tradeoff between using little water and misting to keep the roof cool versus using more water and trickling to retain the heat gain in warm water is interesting.
nick- forward to your newsgroups if useful--drew
Nick
Puddin' Man
Usenet Archive
You are correct, Kind Sir.
the runoff water, which has been heated, not cooled. It doesn't cool the house, but just reduces the solar heating.
You are again correct, Kind Sir.
It would be more effective if
you have minimal ceiling insulation and minimal venting between the insulation and the roof (as is often the case in many "flat" roof houses).
Not the case. Standard-looking gable roof, R-30 insulation. Little exhaust fan doesn't cool crawl-space much. Whole-house fan is not used except late at nite and very early in the morn.
I'm still inclined to think that drastic reduction of solar heat on roof surface would be very helpful.
Lots of folks water their lawns/gardens. I just wanna water my po' scorchingly-hot roof. :)
Anybody got ideas on how to mount, say, 2 sprinklers and a hose on a gable roof without piercing any shingles?
Cheers,
Puddin'
pjm
Usenet Archive
Fool.
The roof is not designed for that - for continuous watering. COUNT on it that you will destroy the roof.
It's designed to get rained on SOMETIMES, not ALWAYS.
Click every day here to feed an animal that needs you today !!!
http://www.theanimalrescuesite.com/
lisac
