Ideal Response 120 combi - flashing LED and no heating
bof
On an Ideal Response 120 combi, does anyone know what a flashing
"Central Heating" LED (behind the cosmetic cover) means? The symptoms
are the boiler won't light if the CH is on though the pump pumps the CH
water OK and the DHW works.
MTIA
E
Ed Sirett
THE stock fault for this boiler is a leaking heat exchanger.
The usual presenting symptoms are that the boiler won't light because the
ignition is wet.
bof
ignition is wet.
Thanks for the reply. The boiler lights OK when it's DHW, and the CH
doesn't get hot even when the DHW is running. I'm sure the pump's OK as
when I switch off the DHW there's a couple of seconds surge of hot in
the CH.
E
Ed Sirett
the CH.
Firstly I'm sorry if I put you on the wrong trail here. You may well have
a model that has not yet eaten its heat exchanger (yet).
I don't have a manual for this model - what does it say?
The FAQ for uk.diy is at http://www.diyfaq.org.uk
Choosing a Boiler FAQ http://www.makewrite.demon.co.uk/BoilerChoice.html
Doctor Drivel
Check the pressure vessel charge. This goes flat quickly on these models.
Check the system pressure. It has a low pressure switch, so if pressure low
problems. I'm not sure if it also has a CH flow switch, if so check this.
bof
In message <[email protected]t>,
models. Check the system pressure. It has a low pressure switch, so if
pressure low problems.
If the pressure's stable and, from prior experience, if the pressure
does drop it won't light the DHW either.
Thanks, the CH light flashes continuously, irrespective of whether the
CH/DHW/stat switch etc. are on or off, which seems to imply that there's
an internal fault of some kind before attempting to run the CH.
E
Ed Sirett
In message <[email protected]>,
There's a reset swtich somewhere IIRC.
bof
First thanks for all the suggestions. The cutout switch I know of is on
the bottom right, but if that pops out it shuts off the DHW and the CH.
This fault is something specific to the CH.
