How to lubricate desk chair casters
micky
I have a nice desk chair, except only about 3 of the 10 wheels on the
5 casters rotate.
The wheels arre modern, all black, with a hood around the tops of the
wheels, but not the sides, like on a car sort of, all plastic except
the axle for the wheels and axle for the swiveling. I'd look for a
picture but my broswer is frozen again. .
Any tips on how to lube them.
I think I recall with casters of this type I could pry the wheels off
the axle and then do a good job of cleaning and oiling. Do the
wheels normally pry off.
But now I spray WD-40 hoping it will seep between the wheel and the
body of the caster, but it doesn't help much.
Thanjks.
Steve B
5 casters rotate.
Thanjks.
Lithium spray.
Thanjks.
Steve
Sonny
And cheap plastic casters? Get some new casters.
There is something jammed in the axle area.... thread, hair, carpet
fibers, something. I don't think you can successfully they them apart
and put them back together. The best bet, if you keep them, is to use
needle nose pliers to remove whatever is jamming them/wrapped around
the axle, if you can access the debris.
