How to connect to thin walled 32mm P trap?
Guest
I've got a chromed 32mm basin trap but the metal is very thin and a
compression 32mm fitting won't close onto it. The o/d is about 32.5mm
whereas the spec for solvent pipe is 36mm o/d and push-fit pipe is 34mm o/d.
This must be a standard problem with an easy solution for "them as knows".
Dave
H
Heliotrope Smith
Dave
A universal coupler/fitting is widely available to connect you chrome pipe
to any other type of fitting.
http://www.polypipe.com/polypipe/controller?action=BP-Products&categoryID=312
is but one source.
