How do i change belt on T/D Hotpoint TDL54N
  • Thread starter andrew_lane_1965
  • Start date
andrew_lane_1965
I have took this thing a apart and cant see any tensioner pulley
wheels on it so i`m lost now. All the replys mension pulley tension
wheels and i cant see any? my belt size is 1860mm which when i put on
seems way to big - help please cos its really frustrating as i know
belt replacement is fairly sraight forward - I think!!
E
EricP
They are called jockey wheels and live in the bottom next to the
motor. A little rod with a small black wheel on top on a spring.
andrew_lane_1965
Ive just had a look and cant see anything but the motor on its own sat
bottom, towards the centre back of the unit. definatly no jockey wheel
close to it or on it?? Its just a basic motor with a rod through the
center, one end for the metal fins and the other ribbed (presumably
for the ribbed belt to fit onto). Is there any way this thing dosnt
have a jockey wheel but and alternative way of pulling the belt tight?
E
EricP
The cheap &^%^s must have changed the design after I left.
The belt tightens when you put the front back on and re-engage the
door surround in the drum front. But without at least one jockey
wheel, I can't see how tension is supplied. Sorry.
andrew_lane_1965
wheel, I can't see how tension is supplied. Sorry.- Hide quoted text -
- Show quoted text -
Ok EricP thanks for your help - i`m at a loss now cos if this belt did
go around the front of the drum as alot of people are mentioning in
the posts then some hoe the belt has to make its way to the back to
align onto the motor. Hmm! looks like i`ll have to get a guy out and
pay the price (ouch)!
cheers mate
powerstation
Joe said:
Some times the adjustment is from the motor, check that.
Joe
They did away with tensioners ages ago, the new belt is a stretch belt,
check the belt markings against your replacement you must have the wrong
one.
