House settlement repairs - fixing cracked lintels
L
l.c1
I am getting a bit doubtful about doing this myself but I thought I'd
see if there is anyone who has !
I live in an 1870's property that has signs of settlement, the
property is of solid stone construction with some quite large stones,
e the lintels are 36" by 8".
These have showed sign of cracking, the crack is the height of the
stop but does not appear to be all the way through. I have been
speaking to a builder who I casually know and he has suggested that he
has seen three ways of fixing this. These are
1. "Stitching in" - This seems to be placing steel bars above the
cracked stones so that they then take the weight of the structure and
hence no additional weight on the cracked stone so they wont get
worse.
2."Stapling" - cut about 4 inches off the front of the stone and then
fire in staples which will stop re-enforce the stone and prevent the
cracking getting worse. The 4" that were removed are replaced by a
stone mix which faces off the repair.
3.Replacing the stone is also an option but have you seen the price of
stone these days !!!
Anyone done any of these ?
If so comments appreciated...in fact any comments appreciated,
Cheers
l.c
RobertL
worse.
before you start patching it up, are you sure the movement has
stopped? if it is still moving perhaps there is a leak in the drains
or water supply pipe somewhere. if this is movement that took place
soon after the house was built then that;'s one thing, but it it has
started recently then in most cases subsidence is due to water leakage
(washing out the finer grin materials from the foundations. This
needs to be fixed.
Robert
L
l.c1
needs to be fixed.
Robert- Hide quoted text -
- Show quoted text -
Fair point, there are no new crack that I can see, the plaster is
still on the walls plus windows, doors etc look okay.
These wall are beside a concrete walkway and there are no signs of
bits falling off or moving. I might buy some glass straws though !!
Cheers
L.c
F
fred
worse.
None of the above but I found recently that one of my sandstone lintels
had been repaired by resin injection and a very nice job it is too. It
looks as if the lintel was given some light support underneath with a
flat steel plate of approx 8mm thick and about half the width of the
lintel, placed at the back so as to be unobtrusive. The crack, near one
end, was resin injected and the face re-finished to match the sandstone.
It was such a good job that I hadn't notice until I was replacing a
casement on that window. Highly recommended.
In contrast I've seen some really cheap and nasty repairs done on
sandstone lintels, some with 8mm angle, yug.
What's the stone type?
L
l.c1
(e-mail address removed) writes
fred
Plusnet - I hope you like vanilla- Hide quoted text -
The building is Sandstone - Resin injection ... Hmmmm
I will need to start googleing this stuff !!!
Cheers Fred.
F
fred
Cheers Fred.
Differential settlement on sandstone buildings is an uber common source
of cracks, particularly on mullions and lintels, loads of concentrated
stress on a soft material. Many can remain stable for decades but there
are situations where a proper fix is required. If you are near a major
city with lots of sandstone buildings then that would be a good target
location for your search for repairers, it really is a specialist job.
Good luck
mail
worse.
Cheers
l.c
Dear l.c
Outside my direct field but I do have some experience of this on site.
consider various options and points
1) the "end" of the crack should be drilled as a stop point of the
stress point - this may be difficult to determine let alone do in
practice but the issue should be considered
2) helibars can be drilled through the lintel if there is close enough
access from the side
3) the load above can be taken off it with reinforcing as you suggest
- I have in mind stainless steel bars set in mortar but to do this you
may have to needle pin and/or provide connections on the bars by doing
it in sections
4) a flat metal plate under as has been suggested but this would be
visible
5) rebuild an "arch" above ( over expensive)
I would avoid like the Plague any use of resins with sandstone despite
glowing comments on two grounds
a) not reversible - a good principle to apply to any conservation
repair
b) such dissimilar materials with repect to water movement and
concommitant freewze thaw cycles
Chris
meow2222
worse.
Cheers
l.c
You're in luck, its not usually necessary to do anything. Lots of old
properties were built with no lintel at all, and catastrophic failures
are very rare, though cracking is common. The lintel is normally a
backup device rather than the primary support. Although a split lintel
has much less strength than a whole one, there are still 2 mechanisms
in operation that continue to give it a backup support role.
1. An 8" high lintel would have to move sideways in order to mvoe
downward, just like an arch. Arches are pretty stable, 8" split
lintels ditto.
2. As the lintel ends overlap the window edges, there is a lever
effect in operation - for the centre to drop, the brick/stone above
the lintel ends would
have to rise up, and that just isnt likely to occur.
If its a big wide opening you may need a repair, but in most cases
its not really an issue.
As an illustration of the lintel's backup role, I still remember a
large house built with no lintels anywhere, not even over the double
width garage(s). Decades later the only issue that cropped up was some
cracking to a garage that needed repair.
NT
Considering options for addressing structural cracks in my 1870's stone property – seeking advice and experiences on methods like 'stitching in,' 'stapling,' or stone replacement. Any insights or recommendations?
jagga009
