Home Depot Home Services: Recommended?
Discussion in 'Home Repair' started by frank1492, Nov 4, 2003.
  1. frank1492
    frank1492 Guest
    My GF just had Home Depot do an estimate for a new roof
    for her house. They are selling her 50 yr shingles and promises
    for a super job that will be completed in one day. She has
    already signed a contract and won't tell me what they are
    charging her. No one else did an estimate for the work.
    Comments? And what level of quality can she expect?
  2. frank1492
    CBHvac Guest
    Ok..first of all, Home Depot actually has NO installers...none..
    They are going to use the cheapest labor they can find, meaning, a roofing
    company that will do the job as cheap as possible, and still allow HD to
    make money..
    She could have probably saved a bundle, by doing herself, what Home Depot
    did, and thats hiring the company herself.
    Home Depot sells Trane AC too right?
    They simply offer one for display, and subcontract out with the authorized
    Trane rep in the area to do the installations for less than they would
    normally, but charge the homeowner more than the same company would have,
    installing it at normal prices....
    Its all about one thing...convience.
    CBHvac, Nov 4, 2003
  3. frank1492
    frank1492 Guest
    They told her they are not sub-contractors
    and are employees of HD.
  4. frank1492
    George Guest
    That is so she gets a warm and fuzzy feeling. Reality is they do not have
    their own installers but simply find whomever will work cheap and then beat
    them up more for a lower price.
    George, Nov 5, 2003
  5. frank1492
    CBHvac Guest
    Unless HD has changed things dramatically in the last week or
    CBHvac, Nov 5, 2003
  6. frank1492
    jduprie Guest
    she can expect the cheepest job they (home depot) can get. That means
    low-end materials, low-end labor, and low end results. A 50 year warranty on
    the shingles is meaningless. It only covers the shingles if they are
    properly installed, and even then, only covers the shingles (noth the labor,
    underlayment, or damage to the structure when the poorly installed shingles
    leak). As an example, most shingles specify a distance from the edge that
    nails should be, and a set number of nails per shingle. They also specify
    the amount of overlap for each row, how much gap to leave at the end of a
    run, what type of underlayment, roof pitch, etc. the shingle is supposed to
    be used with. If you don't believe me, go to the Depot, and actually look at
    a package of shingles. Most brands print it right onthe package.
    Now imagine that you're some college kid getting paid 8-10 bucks an hour
    to install a roof. chances are good its either really hot or really cold
    (just because thats the way the world works). Just for fun, climb up on your
    roof and just sit there for an hour or two - you'll be amazed at how
    cold/hot it gets up there. Now imagine that you have to handle the shingles
    (they're either frozen or hot enough to burn), place them in exactly the
    right spot, and put in nails at the right places and the right depth.
    Remember, this is all for a few bucks an hour...... What quality of work do
    you *think* they're going to do?
    jduprie, Nov 5, 2003
  7. frank1492
    CBHvac Guest
    True, BUT, that is not the way the world works and you know it.
    2 million? thats all?
    BTW, if it matters, once HD has your money, you play hell getting
    satisfaction, whereas a smaller company, that relies on its good reputation,
    will be willing to fix a botched job much faster.
    I should know..I have already started to service some of the crap Trane
    installs done a while back by HD subs..
    CBHvac, Nov 5, 2003
  8. frank1492 Spilled my beer when they jumped on the table and
    They lied...sorry.
    Thund3rstruck, Nov 5, 2003
  9. frank1492
    Tony Hwang Guest
    Ditto. HD is middle man.
    Tony Hwang, Nov 5, 2003
  10. frank1492
    Jimmy Guest
    Yep. Expect crappy work followed by a nightmare trying to get them
    to do the repairs under warranty. Eventually they'll do something
    less than great to repair it and you'll never be happy.
    Jimmy, Nov 5, 2003
  11. frank1492
    Tekkie Guest
    frank1492 posted for all of us....
    I think the quality could be good or BAD. Since she most likely has 3 days
    to cancel, take advantage of it. Have her ask for references, licenses,
    insurance. This will most likely prove what the others have said per HD NOT
    having their own crews. It's her HOME, something not be messed with-called
    piece of mind.
    Tekkie, Nov 5, 2003
  12. frank1492
    TURTLE Guest
    This is Turtle.
    the highest price , the lowest quality, and the fastest completion of the
    job ever. You better talk to your GF.
    TURTLE, Nov 5, 2003
  13. I've heard good stories, I've heard many bad stories. Depends on who the
    installers happen to be for the job. I'd rather invest my money at the
    casino; at least you know what the odds are.
    Edwin Pawlowski, Nov 5, 2003
  14. frank1492
    Chuckles Guest
    I got a roofing estimate from them. It was three times what I ultimately
    paid another licensed roofer. This doesn't mean anything for your area
    since as others have said HD uses local contractors, they don't have
    consistent prices or quality.
    Chuckles, Nov 5, 2003
  15. frank1492
    frank1492 Guest
    My sincere thanks to all who have offered their
    opinions. Despite all the negative comments, she
    has decided to go ahead with it. I am hoping her
    experience is close to the better one that a couple
    of you have reported. It could certainly happen.
    frank1492, Nov 6, 2003
  16. frank1492
    CBHvac Guest
    Just tell her good luck, and hope the financing they gave her was worth it.
    An old friend of mine from high school has one of the largerst roofing
    companies in the area, and I asked him if Lowes or HD had aproached him
    about roofing projects, and his reply was that they had, but when they found
    out that his cost, and finance rate was lower than what they charged, for
    better materials, they about broke their necks to get him to do it.
    His reply was that he made better money fixing their subs screw ups..:)
    CBHvac, Nov 6, 2003
  17. frank1492
    frank1492 Guest
    I'll give her your regards, and thanks
    for the additional info (which I will pass on.)
    frank1492, Nov 7, 2003
  18. frank1492
    Andrew Guest
    Ya, I've been screwed by Home Depot "at home services" and I would
    recomend that anyone who has also been burned by Home Depot, Please
    file complaints with the BBB and their states Attorney Generals office
    and the Georga state Attorney Generals office ( Home Depot has their
    HQ in Atlanta )
    Its bad enough that fly-by-night inc. does this sort of thing, but a
    multibillion dollar company with a "good name" to protect. Well its
    NOT the way to cultivate customer loyalty, I for one will NEVER shop
    at any home depot.
    They have lost a customer.
    Just my $0.02 worth.
    Andrew, Nov 7, 2003
  19. frank1492
    bx Guest
    I got the same story from HD. Doing a search, I found that HD had purchased
    Installed Products USA (which I guess is a nationwide roofing company). Does
    this mean that all of the roofing projects are handled by IPUSA and
    technically HD employees? HD gave a big song and dance about how they were
    changing their At Home Services image by buying out the sub-contracted
    companies that performed well so they would be HD employees with HD
    standards. Their claim was that they were starting with the roofing group
    first, then would expand to other services.
    I've had a very frustrating time with the "Installation Consultant" (i.e.,
    used car salesman in HD uniform). After all of the promises, when it came to
    contract time, not everything was listed and those that were listed, were
    often incorrect - and passed off as either a 'typo' or his retraction saying
    'he never said that'.
    I hope the sales thing is just that - sales. All sales are nothing more than
    smoke/mirrors. But assuming the new way of services is correct, are the
    project managers and workers any better? Does anyone here have any inside
    experience as to this supposed new HD way?
    bx, Nov 10, 2003
  20. frank1492
    Brian Elfert Guest
    Doesn't HD own an HVAC wholesaler? Couldn't HD provide the equipment to
    a third party installer?
    Brian Elfert
    Brian Elfert, Nov 11, 2003
